Hi, Team,
We need to change the FS according to the configuration in runtime , but found there have large opportunity the false antialiasing responce ,when change from 48k to 96k, or 96k to 192k. The amplitude responce curve also changed with the FS, became much dip in the edge and not flat as normal run. The PLL config is as your datasheet.
Could you give some advice on the issuse?
James
