TAS5782MEVM: TAS5782MEVM Mute Channels from PPC3 GUI
Part Number: TAS5782MEVM
Hallo
We have a speaker setup here with Woofer and Tweeter channel. In order to do the tuning using the PPC3 GUI, we need to have an option to Mute and Unmute the Tweeter and the Woofer Channel separately. But I have not found an way to do it using the PPC3 GUI so far. Is there a possibility to do that?
Is there a documentation on the Programmable Dynamic Equalizers?
The Smart Amp has a Smart Bass Feature is there some documentations on that also?
  • Hi Shauk,
    For the first question, I would recommend taking a look at register 3. This controls the left and right channel mutes individually. See table below:
    For the last two questions, We have a document that should help you get a better understanding of the process flows. It's called the TAS5782M Process Flows. It's a very useful technical document that should cover both the dynamic control and smart amp features in this device. Let me know if this helps or if you still need clarification!
    Robert Clifton
