Other Parts Discussed in Thread: TLV320AIC3262, TLV320AIC3268
Hi team,
My customer is evaluating our TLV320AIC3254.
They have a quick search on TI forum and find following topic
All the codecs miniDSP supports the noise reduction block. It can be used as the following document mentions: 7245.Noise Reduction with Variable Filter Bands.pdf
However, the microphone beam forming block is only supported by the TLV320AIC3262 and the TLV320AIC3268 : 3036.Microphone Beamforming.pdf
They need your help to know what is the restriction of Codec and if you could provide latest related AP note that is most appreciated.
Could you kindly let us know whether it can support below spec. Thanks.
Microphone CODEC |
shall be possible to adust the sampling rate (at least 22k, 32, 44k, 48k) |
Noise Reduction Filter |
shall be possible to enable/disable noise reduction filter |
Microphone CODEC |
The codec shall contain/support adaptative beamforming capabilities allowing voice tracking, background noise reduction and accoustic echo cancelation. |
Microphone |
shall be possible to adjust the audio level of each DMIC |
Audio codec |
The codec shall be used to drive 1 x Speaker and 2 x DMICs |
Echo/Noise Cancellation |
The device shall be capable of echo cancellation/ noise reduction to support future features. This could be as part of the audio CODEC or the cellular modem. |
