Hi Guys,
I am getting the following message when I am running ADC3101 Control Software (CS).
I've installed the latest LabView runtime engine and still the SW does not start.
Please HELP
Hi Guys,
Please HELP
Hi Nikolay,
Have you tried uninstalling and reinstalling the EVM software? This is a fairly old software so the latest Labview Run-Time engine is likely not compatible and you need version 8.5.1 or a version that is still compatible.
Zak
Sadly still does not work after 8.5.1 installation
Hi Nikolay,
Zak
Hi Nikolay,
Can you confirm that you are running that software as an administrator? This is required for the GUI to run properly.
Zak
Hey Nikolay,
I'm sorry, I know issues like this are frustrating. The GUI itself should install its own Labview Runtime engine as part of the GUI framework and this does not create a separate runtime file in your programs. If you have other runtime engines installed though I am thinking this might interfere with its own labview calls. I would suggest deleting any standalone Labview runtime engines you have, and then re-installing the ADC3100 GUI.
Zak
