I'm working on a prototype audio amplifier that uses LME49720s, but the circuit seems to be picking up RFI. Whenever my wifi base station is switched on, the noise floor looks like the image below. I've attached the schematic so you can see what I've got so far.
Things I've tried are:
Adding 100R in series with the power rails immediately prior to the decoupling.
Shorting R18 and R19 to run at unity gain
Grounding the non-inverting inputs
Cutting the traces to the potentiometer at the output to limit noise being picked up that way.
Any idea what I should try next? Any help or ideas are much appreciated.
Many thanks in advance,
Wes
