Other Parts Discussed in Thread: CC3200
I tried to test the codec on the cc3200 audio boosterpack by generating the beep sound.
Here is my code:
#ifndef __TI3254_H__
#define __TI3254_H__
// If building with a C++ compiler, make all of the definitions in this header
// have a C binding.
#ifdef __cplusplus
extern "C"
#endif
#define CODEC_I2C_SLAVE_ADDR ((0x30 >> 1))
#define CRYSTAL_FREQ 40000000
#define SYS_CLK CRYSTAL_FREQ
#define TI3254_PAGE_0 0x00
#define TI3254_PAGE_1 0x01
#define TI3254_PAGE_8 0x08
#define TI3254_PAGE_44 0x2C
#define PAGE_CTRL_REG 0x00
// Page 0
#define TI3254_PAGE_SEL_REG 0x00
#define TI3254_SW_RESET_REG 0x01
#define TI3254_CLK_MUX_REG 0x04
#define TI3254_CLK_PLL_P_R_REG 0x05
#define TI3254_CLK_PLL_J_REG 0x06
#define TI3254_CLK_PLL_D_MSB_REG 0x07
#define TI3254_CLK_PLL_D_LSB_REG 0x08
#define TI3254_CLK_NDAC_REG 0x0B
#define TI3254_CLK_MDAC_REG 0x0C
#define TI3254_DAC_OSR_MSB_REG 0x0D
#define TI3254_DAC_OSR_LSB_REG 0x0E
#define TI3254_DSP_D_CTRL_1_REG 0x0F
#define TI3254_DSP_D_CTRL_2_REG 0x10
#define TI3254_DSP_D_INTERPOL_REG 0x11
#define TI3254_CLK_NADC_REG 0x12
#define TI3254_CLK_MADC_REG 0x13
#define TI3254_ADC_OSR_REG 0x14
#define TI3254_DSP_A_CTRL_1_REG 0x15
#define TI3254_DSP_A_CTRL_2_REG 0x16
#define TI3254_DSP_A_DEC_FACT_REG 0x17
#define TI3254_AUDIO_IF_1_REG 0x1B
#define TI3254_DAC_SIG_P_BLK_CTRL_REG 0x3C
#define TI3254_ADC_SIG_P_BLK_CTRL_REG 0x3D
#define TI3254_DAC_CHANNEL_SETUP_1_REG 0x3F
#define TI3254_DAC_CHANNEL_SETUP_2_REG 0x40
#define TI3254_LEFT_DAC_VOL_CTRL_REG 0x41
#define TI3254_RIGHT_DAC_VOL_CTRL_REG 0x42
#define TI3254_LEFT_BEEP_CTRL_REG 0x47
#define TI3254_RIGHT_BEEP_CTRL_REG 0x48
#define TI3254_BEEP_LEN_MSB 0x49
#define TI3254_BEEP_LEN_MID 0x4A
#define TI3254_BEEP_LEN_LSB 0x4B
#define TI3254_SINE_MSB 0x4C
#define TI3254_SINE_LSB 0x4D
#define TI3254_COSI_MSB 0x4E
#define TI3254_COSI_LSB 0x4F
#define TI3254_ADC_CHANNEL_SETUP_REG 0x51
#define TI3254_ADC_FINE_GAIN_ADJ_REG 0x52
#define TI3254_LEFT_ADC_VOL_CTRL_REG 0x53
#define TI3254_RIGHT_ADC_VOL_CTRL_REG 0x54
//Page 1
#define TI3254_PWR_CTRL_REG 0x01
#define TI3254_LDO_CTRL_REG 0x02
#define TI3254_OP_DRV_PWR_CTRL_REG 0x09
#define TI3254_HPL_ROUTING_SEL_REG 0x0C
#define TI3254_HPR_ROUTING_SEL_REG 0x0D
#define TI3254_LOL_ROUTING_SEL_REG 0x0E
#define TI3254_LOR_ROUTING_SEL_REG 0x0F
#define TI3254_HPL_DRV_GAIN_CTRL_REG 0x10
#define TI3254_HPR_DRV_GAIN_CTRL_REG 0x11
#define TI3254_LOL_DRV_GAIN_CTRL_REG 0x12
#define TI3254_LOR_DRV_GAIN_CTRL_REG 0x13
#define TI3254_HP_DRV_START_UP_CTRL_REG 0x14
#define TI3254_MICBIAS_CTRL_REG 0x33
#define TI3254_LEFT_MICPGA_P_CTRL_REG 0x34
#define TI3254_LEFT_MICPGA_N_CTRL_REG 0x36
#define TI3254_RIGHT_MICPGA_P_CTRL_REG 0x37
#define TI3254_RIGHT_MICPGA_N_CTRL_REG 0x39
#define TI3254_FLOAT_IP_CTRL_REG 0x3a
#define TI3254_LEFT_MICPGA_VOL_CTRL_REG 0x3B
#define TI3254_RIGHT_MICPGA_VOL_CTRL_REG 0x3C
#define TI3254_ANALOG_IP_QCHRG_CTRL_REG 0x47
#define TI3254_REF_PWR_UP_CTRL_REG 0x7B
// Page 8
#define TI3254_ADC_ADP_FILTER_CTRL_REG 0x01
// Page 44
#define TI3254_DAC_ADP_FILTER_CTRL_REG 0x01
#ifdef __cplusplus
#endif
#endif /* __TI3254_H__ */
void AudioCodecBeepConfig() {
AudioCodecReset(AUDIO_CODEC_TI_3254, NULL);
Report("Beep config \n\r");
AudioCodecRegWrite(TI3254_CLK_MUX_REG, 0x07); // #Set PLL_CLKIN=BLCK and CODEC_CLKIN=PLL_CLK
AudioCodecRegWrite(TI3254_CLK_PLL_P_R_REG, 0x91); // #PLL powered up, set PLL variable P=R=1
AudioCodecRegWrite(TI3254_CLK_PLL_J_REG, 0x20); // Set PLL variable J=32
AudioCodecRegWrite(TI3254_CLK_PLL_D_MSB_REG, 0x00); // # Set PLL variable D(msb)=0
AudioCodecRegWrite(TI3254_CLK_PLL_D_LSB_REG, 0x00); // D(lsb)=0
AudioCodecRegWrite(TI3254_AUDIO_IF_1_REG, 0x01); // # Mode=I2S, Word length=16, BCLK, WCLK are inputs to codec
AudioCodecRegWrite(TI3254_CLK_NDAC_REG, 0x84); // #NDAC powered up and set to 4
AudioCodecRegWrite(TI3254_CLK_MDAC_REG, 0x84); // #MDAC powered up and set to 4
AudioCodecRegWrite(TI3254_DAC_OSR_MSB_REG, 0x00); // #DOSR=128, DOSR(9:8)=0
AudioCodecRegWrite(TI3254_DAC_OSR_LSB_REG, 0x80); // #DOSR(7:0)=128
AudioCodecRegWrite(TI3254_CLK_NADC_REG, 0x84); //#NADC powered up and set to 4
AudioCodecRegWrite(TI3254_CLK_MADC_REG, 0x84); //#MADC powered up and set to 4
AudioCodecRegWrite(TI3254_ADC_OSR_REG, 0x80); // AOSR = 128 ((Use with PRB_R1 to PRB_R6, ADC Filter Type A)
AudioCodecRegWrite(TI3254_DAC_SIG_P_BLK_CTRL_REG, 0x19); // DAC Signal Processing Block PRB_P19
AudioCodecRegWrite(TI3254_ADC_SIG_P_BLK_CTRL_REG, 0x4); // ADC Signal Processing Block PRB_R4
AudioCodecRegWrite(TI3254_DAC_CHANNEL_SETUP_1_REG, 0xD6); // Left and Right DAC Channel Powered Up
AudioCodecPageSelect(TI3254_PAGE_1); //Select Page 1
//w 30 21 46 # De-pop, Driver power-on time=600ms, Step time=4ms
AudioCodecRegWrite(0x21, 0x46);
//w 30 1F C6 #Power on HP drivers
AudioCodecRegWrite(0x1F, 0xC6);
//w 30 23 88 #DAC_L routed to HPL, DAC_R routed to HPR
AudioCodecRegWrite(0x23, 0x88);
//w 30 28 0E #HPL driver unmuted and gain set to 1dB
AudioCodecRegWrite(0x28, 0x0E);
//w 30 29 0E # HPR driver unmuted and gain set to 1dB
AudioCodecRegWrite(0x29, 0x0E);
//w 30 24 00 #Analog Volume control gain set to 0dB for HPL
AudioCodecRegWrite(0x24, 0x00);
//w 30 25 00 # Analog Volume control gain set to 0dB for HPR
AudioCodecRegWrite(0x25, 0x00);
//w 30 2E 0B #MICBIAS=AVDD
AudioCodecRegWrite(0x2E, 0x0B);
//w 30 30 40 #MIC with Rin=10k
AudioCodecRegWrite(030, 0x40);
//w 30 31 40 #CM with Rin=10k
AudioCodecRegWrite(0x31, 0x40);
//w 30 40 0C #DAC unmated
AudioCodecRegWrite(0x40, 0x0C);
//w 30 51 80 #Power ADC channel
AudioCodecRegWrite(0x51, 0x80);
//w 30 52 00 #Unmute ADC channel
AudioCodecRegWrite(0x52, 0x00);
void AudioCodecBeep()
Report("Beep setup \n\r");
AudioCodecPageSelect(TI3254_PAGE_0); // Select Page 0
//Writing Beep length to registers 73,74,75 and 30 being the Codec address.
//73=49 in hex and so on.
AudioCodecRegWrite(TI3254_BEEP_LEN_MSB, 0x01);
AudioCodecRegWrite(TI3254_BEEP_LEN_MID, 0x77);
AudioCodecRegWrite(TI3254_BEEP_LEN_LSB, 0x00);
//Now writing Sine and cosine coefficients MSB first then LSB in
//76,77,78,79
AudioCodecRegWrite(TI3254_SINE_MSB, 0x23);
AudioCodecRegWrite(TI3254_SINE_LSB, 0xFB);
AudioCodecRegWrite(TI3254_COSI_MSB, 0x7A);
AudioCodecRegWrite(TI3254_COSI_LSB, 0xD7);
//now that all coefficient settings are done, we can move on to control the volume of left and right
//channel beep and turn on beep. Assuming Volume of left and right beep= –2dB
AudioCodecRegWrite(TI3254_RIGHT_BEEP_CTRL_REG, 0x04); // Making gain of right –2dB and making right and left channel independent
AudioCodecRegWrite(TI3254_LEFT_BEEP_CTRL_REG, 0x84); //Make gain of left channel-2dB and turning on Beep
int main()
long lRetVal = -1;
BoardInit();
// Pinmux Configuration
PinMuxConfig();
// Initialising the UART terminal
InitTerm();
// Initialising the I2C Interface
lRetVal = I2C_IF_Open(1);
if(lRetVal < 0)
ERR_PRINT(lRetVal);
LOOP_FOREVER();
// Configure Audio Codec
UART_PRINT("Setting up the beep \r\n");
AudioCodecBeepConfig();
AudioCodecBeep();
// Start the Speaker Task
//lRetVal = osi_TaskCreate( Speaker, (signed char*)"Speaker",OSI_STACK_SIZE, \
NULL, 1, &g_SpeakerTask );
/*if(lRetVal < 0)
ERR_PRINT(lRetVal);
LOOP_FOREVER();
while (1)
