Dear Sir
TAS5760L can be used Hi-resolution audio ( BW =40KHz +/- 3dB) if fs=96KHz ?
Customer want to use TAS5760L foe Hi-resolution audio.
Best Regards
Hi, Shibatani-san,
The TAS5760x supports operation up to 40KHz when sample rate is 96KHz. The high cutoff frequency is about 44KHz for 96KHz sample rate. The LC filter should be adjusted to change the cutoff frequency above 40KHz.
-Diego Meléndez López
Audio Applications Engineer
Hello Diego san,
Thank you so much for your reply.
If customer used following LC filter and sampling frequency fs=96KHz, do you agree TAS5760L or TAS5760M
output frequency responce meets 40KHz +/-3dB?
RL=4ohm.
L=7uH C=0.68uF :fc=72KHz
http://www.tij.co.jp/jp/lit/an/slaa701a/slaa701a.pdf
Sorry to bother you again
Best Regards
