LMV1012: when work with MIC, there is a lot of ground noise.
Prodigy 130 points
Part Number: LMV1012
Dear TIs,
when we use LMV1012-15 as a MIC signal amplifier as attachment? it come out a big groud noise, could you kindly help to tell us why? how to aviod this issue?
thanks a lot!Click here to play this audio clipClick here to play this audio clip
电路图.pdf
  • Hello Ryan,
    I have reviewed the schematic and have a couple of questions.
    Is Term1 connected to Vdd and Term2 to GND? and Where are you getting the output signal?
    Best Regards
    José Luis Figueroa
    Audio applications Engineer
  • In reply to José Luis:
    Dear José
    Term1 output will be used as datasheet with res/CAP, term2 is connected to GND. we get the output at term1.
    thanks a lot!
