Part Number: TPA3251
As the subject says.
The context: For a Stereo BTL configuration (Figure 25, Section 10.2.1 in TPA3251 datasheet), I have an input stage that already outputs a differential signal with 0V common-mode voltage (i.e., one signal in the differential pair is Vout, the other one is −Vout). In this case, can I avoid the DC-blocking capacitors?
Carlos
