Other Parts Discussed in Thread: PCM1795, OPA1632
Hi TI Experts,
In my design I drive TAS3255 directly from PCM1795 DA converter. My D/A output low-pass filter use OPA1632 fully differential amplifier:
I would like to implement also PFFB directly in this design without using additional buffers / summing amplifiers between low-pass section and TPS3255 input. Could you tell me how to adjust / calculate the components? The component values in low-pass filter stage are taken directly from PCM1795 datasheet. Can I simple adjust PFFB components and R138/R139/R158/R159? Or I need to redesign my low impedance low-pass filter stage?
Thanks for your support, Tomasz
