Part Number: PCM2706C
my customer is using PCM2706C, I2S as communication.
They can't volume up or down by pressing the key. But the mute key can work well.
I can send you the schematic if needed.
Hi Howard,
The volume key of the PCM2706C controls the volume level in the host system, not the actual volume of the I²S output, which data is actually sent by the computed through USB bus.
-Diego Meléndez López
Audio Applications Engineer
Howard,
The volume control of the PCM2706C changes the main volume mixer of the USB audio device, so it is possible that the software used to playback audio is not being affected by this change. Is it possible to use a different software to see if the volume key changes the output amplitude?.
