Part Number: TAS5548
Other Parts Discussed in Thread: TAS5614A
Dear all,
If I select the lowest possible value for the modulation index (xFF in register x16, hence a modulation index of 87.40% for channels 1 and 2), can I expect a limitation of the output power and therefore of the THD?
If the question makes sense (I'm not sure it does), would you have any figures in the case where the power stage is a TAS5614A?
Thanks and regards,
Jean-Jacques
