Hi, Team,
My customer test the THD+N ratio for the TLV320AIC3104 with different sample rate. They found the performance for THD+N with 48k sample rate have some issue, it is normal when the sample rate is 8K and 16K.
The detail info as in the attachment. It have the SCH and test result. Customer set the register with different sample rate as in our datasheet& application note said.
Could you give some suggestion for that? Thanks!THD.docx
