Hi Sir
could you help check above questions,tks!
Now there is no demo board. I use the following PurePath Studio (Home Audio) MiniDSP GDE software to edit the parameters offline, and generate the parameter cfg file such as attachment through Build-Generate Code. How is this file integrated into our software? could you help provide the way how to export register without connect demo board
7633.base_main_Rate48.cfgThe main question is how to write a piece of the following screenshot (no corresponding address?)?
