Hi there,
I'm designing an audio solution using a PCM5102A Directpath DAC.
I am trying to locate the list of TI amplifier IC's that accept a Directpath ground-centered signal as an input.
Specifically I'm looking for a high fidelity >25W 7V-20V (approx) single supply power amplifier, and a 3.3V single supply headphone amp (mono or stereo).
The reason I'm asking here is the TI online catalogue doesn't seem to allow filtering by input type beyond the generic analog/digital/PWM choices.
Most amps I have looked at have an input voltage range of -0.3V to Vcc+0.3V which obviously will not work.
How can I find a list of TI products that satisfy this requirement?
p.s I am still learning so apologies if I've overlooked something obvious
Thank you!
Jerry
