[FAQ] TLV320AIC CODECs and ADCs: How to generate a header (.h) file with PPS
Other Parts Discussed in Thread: TLV320AIC3254
How do I generate a header (.h) files using Pure Path Studio (PPS)?
  • PurePath Studio is capable of generating header files to be used in an end system, as well as TI's script format.
    To enable header file generation follow these steps in PurePath Studio GDE:
    1. Click Tools > Options.
    2. Select the Build tab.
    3. Check the Generate Device Driver Interface option.
    4. Compile the code as usual. A header file will now be generated.
    Refer to the PurePath Studio documentation for details on how to implement into an end system.
    The following app note provides an implementation example for the TLV320AIC3254 : http://www.ti.com/lit/pdf/slaa605.
