Other Parts Discussed in Thread: TAS3251, , TAS5766M, PCM5242, TPA3251
I read in another post that programming the PCM5252 with the Purepath 3 console is not publicly supported. If this is the case how do you program the DSP section to take advantage of the smart amp features? Also does the miniDSP section of the PCM5252 have the same power and capabilities as the DSP section in the TAS3251? And lastly, does the PCM5252 need to be used in conjunction with one of the TI chips D chips to take advantage of the smart amp features?
On a side note I was watching a smart amp webinar and happened to see a screenshot of the Purepath 3 console. And there's a tile there for programming the PCM5252RHVBEM board. But I understand that this board doesn't exist.
Mike
