[FAQ] SRC4192: Differences between the SRC4192 and the SRC4193?
Part Number: SRC4192
Other Parts Discussed in Thread: SRC4193
What are the differences between the SRC4192 and the SRC4193?
  • Here is a table breakdown of the differences between the SRC4192 and the SRC4193.
    Features
    SRC4192
    SRC4193
    Device control
    Hardware controlled
    Software controlled
    Programmable Digital Output Attenuation
    NOT supported
    Supported; Digital attenuation control is adjustable from 0 dB to –127.5 dB in 0.5-dB steps.
    Direct Downsampling option for Decimation filter
    NOT supported
    Supported; This can be used in cases when aliasing is not an issue (ex: when output fs is equal or greater than input fs).
    Advantage: Significant reduction is group delay associated w Decimation filter, allowing lower latency SRC.
    RATIO output
    NOT supported
    Supported; This can be used as an indicator or flag output for host device.
    Reset and Power-down Operation
    Using RST pin; With external clock source active, assert RST low for min 500ns
    Using RST pin; BUT we need to wait at least 500uS after RST rising edge due to internal logic requirements;
    SRC4193 also supports power-down mode [Using PDN bit of Control Register 1]
