Hi team,
My customer follow the sequence as the datasheet.
But there is some sharp sound when they pull high and pull low the SPK_SD pin.
So we suspect it's because there may need a delay between pull SPK_SD and unmute channel, also mute channel and pull SPK_SD low.
Can you help comment the possible cause and help to check if the delay is needed.
Lacey
Thanks a lot!
