Part Number: TPA2001D1
Other Parts Discussed in Thread: TPA2005D1
we have several boards with no audio from TPA2001D1 after approximate one year of operation.
We have replaced one capacitor (Cosc) and the sound is now ok. On some boards we have replaced two capacitors (Cosc and Cbypass).
We use 06033A221JAT2A AVX for Cosc and 0402ZD105KAT2A AVX for Cbypass.
If we install these "bad" capacitors into a some "good" board with TPA2001D1 then we have no more sound. But these "bad" capacitors are perfectly working in some other "good" boards. We have measured the capacitance and it is ok.
What should it be? Are our capacitor partnumbers correct? There are very few requirements for these capacitors in the datasheet, does any additional information exists? Are the recommended capacitors from the datasheet tested for some long time?
Thank you.
