Hi
1.How to use PPC3 to connect TAS2770EVM and play music?
2.When I runing the "system check" on PPC3, it will show "Hardware ID is incorrect".
Hi
Hi Edgar,
Have you tried to go ahead and configure the device through Device Control panel even though Hardware Checks are not completed successfully?
I would expect the device to be able to work correctly even if it shows ID error during Hardware Checks.
-Ivan Salazar
Applications Engineer - Low Power Audio & Actuators
Hi Edgar,
Have you got a chance to test my suggestion above?
Is your EVM working fine?
-Ivan Salazar
