HI,
my Configuration as below:
now have a question,the actual output is no problem, but the high power does not work and the output is not amplified.
Is there any problem with configuration?
# PIN RESET
p Reset 1 # Release the reset pin
d 150
w 30 00 00 # Select Page 0
w 30 01 80 # Software Reset Register
d 150
w 30 07 0A # Register 07 :DAC Datapath Setup Register
w 30 09 00 # Register 09 :Audio Serial Data Interface Control Register B
w 30 25 C0 # Register 37 :DAC Power and Output Driver Control Register
w 30 26 06 # Register 38 :High Power Output Driver Control Register
w 30 29 A0 # Register 41 :DAC Output Switching Control Register
w 30 2A 7C # Register 42 :Output Driver Pop Reduction Register
w 30 2B 00 # Register 43 :Left DAC Digital Volume Control Register
w 30 2C 00 # Register 44 :Right DAC Digital Volume Control Register
w 30 2F 80 # Register 47 ://DAC_L to HPLOUT Volume Control Register
w 30 33 3D # Register 51 :HPLOUT Output Level Control Register X-dB
w 30 36 80 # Register 54 ://DAC_L to HPLCOM Volume Control Register
w 30 3A 3D # Register 58 :HPLCOM Output Level Control Register X-dB
w 30 40 80 # Register 64 ://DAC_R to HPROUT Volume Control Register
w 30 41 3D # Register 65 :HPROUT Output Level Control Register X-dB
w 30 47 80 # Register 71 ://DAC_R to HPRCOM Volume Control Register
w 30 48 3D # Register 72 :HPRCOM Output Level Control Register X-dB
w 30 65 01 # Register 101 :Additional Control Register B
thanks.
