Part Number: TPA3255
Other Parts Discussed in Thread: PMP10215,
Specification for Audio AMP
A. 4-8 ohm
B. 4-8 ohm
C. 0.1THD
C. 20-20K at 100 watts per channel
Hello Kashif,
The PMP10215 doesn't have a high enough supply voltage to provide the specifications you want. If you look at the Output Power vs Supply Voltage figures in the TPA3255 datasheet it will give you a better idea of what would be a suitable PVDD to meet your specification.
Luis
Dear Luis thanks
Thanks for your valuable feedback.
Can you suggest any active power reference design available on TI which I can follow and develop a power supply unit that could meet my requirement.
Kashif
Hello Kashif
https://e2e.ti.com/support/power-management/ would be a better resource to ask about power supply design. Provide information like your max current draw and the Vout should be the PVDD that fits your spec.
Luis
