Part Number: TAS2770
HI,
We are using TAS2770 amplifier , observed no output from the amplifier to speaker (speaker voltage) checked the datasheet and found it was due to software shutdown.
Measured the signals SBCLK, SDIN, FSYNC which were at configured range of frequency. Also, no interrupt in IRQZ pin.
As per datasheet, reason for software shutdown
The device transitions into software shutdown mode if it detects any faults with the TDM clocks such as:
• Invalid SBCLK to FSYNC ratio
• Invalid FSYNC frequency
• Halting of SBCLK or FSYNC clocks, TDM Clock Error.
We don't have the above issues. Also there was no interrupt set.
Kindly, explain why software shutdown occurred eventhough there was no above transition?
