I encounter a problem of using PPC3 :(mono 1.1 mode is selected)
1. How to fractional frequency between the high and low pitch tones? Woofer is used for low pitch tones, can use crossover to adjust, and tweetier is used for high pitch tones. However, there is no crossover option but EQ. So how to adjust high pitch tones?
2. If EQ is used to regulate high-pitched tones, then EQ regulation will affect the regulation of woofer's crossover. How to solve this problem?
3. If woofer connect to high pitch tones(use EQ to adjust), and tweetier connect to low pitch tones(use crossover to adjust), these two will not affect each other, will there be any problem with this testing method?
Thank you very much!
Best regards
Mason
