Hi Team,
My customer is considering to use TLV320AIC3105 under the following Bypass Path Modes,
Could you review whether each bypass path mode is feasible?
Mode-1)
1. (a) Monaural microphone signal is inputted into MIC1L/LINE1L, it is amplified by PGA, it is bypassed ADC and digital block, and it is done volume control at output mixer block
2. (b) Monaural CD radio signal is inputted into MIC2R/LINE2R, it is bypassed PGA and digital block, and it is done volume control at output mixer block.
3. Mixing #1 and #2 signal by output mixer block, and outputted by monaural audio signal
Mode-2)
1. During Mode-1 operation, the (a) monaural microphone signal amplified by PGA is converted into digital data by ADC as LCH audio data.
2. During Mode-1 operation, the (b) monaural CD radio signal amplified by PGA is converted into digital data by ADC as RCH audio data.
3. During Mode-1 operation, #1 and #2 L/R digital audio signals are outputted by audio serial bus I/F.
Mode-3)
1. The (a) monaural microphone signal is muted.
2. The (b) monaural CD radio signal is muted.
3. L/R digital audio signals inputted into audio serial bus I/F are converted into analog audio signals by DAC, L/R signals are mixed by output mixer block, and it is outputted as monaural audio signal.
Mode-4)
2. The (b) monaural CD radio signal is bypassed PGA and digital block, and it is done volume control at output mixer block.
3. L ch digital audio signal which is inputted into audio serial bus I/F is converted into analog audio signal, and it is done volume control at output mixer block.
4. #2 and #3 signals are mixed by output mixer block, and it is outputted as monaural audio signal.
Mode-5)
1. The (a) monaural microphone signal is amplified by PGA, it is bypassed ADC and digital block, and it is done volume control at output mixer block.
3. R ch digital audio signal which is inputted into audio serial bus I/F is converted into analog audio signal, and it is done volume control at output mixer block.
4. #1 and #3 signals are mixed by output mixer block, and it is outputted as monaural audio signal.
Thank you.
Koshi Ninomiya
