Other Parts Discussed in Thread: PCM2902
Dear Sirs,
Application: Transfer the S/PDIF signal to USB
Problem:
1 We use the player based on Broadcom chipset as S/PDIF output,then input the S/PDIF input to PCM2902C board.It is ok.
2 We change the player based on the Hisilicon or Realtek chipset as S/PDIF output,then input the S/PDIF input to PCM2902C board.It can't work.We doubt that PCM2902C can't recognize the signal from the other chipsets.
Pls help to clarify why it can has this issue.
Thanks!
