Team,
I have one question, I am studying the configuration files from different customers and different project, I found some projects masked all the interruption during the initialization, and set it back during the power on. But some of the projects does not have. I want to understand where the requirement come from, or any condition need to meet if we do not want to mask them. Because for some projects, has more channels devices, set those registers is wasting time. Attachment is one of the 4 ch case.
<?xml version="1.0" encoding="utf-8"?> <NV_CATEGORY NAME="PARAM_VALUE" MODE="GU"> <PA_STATUS NAME="FOUR_PA"> <SCENCE NAME="INIT_CHIP" CONTROL_MASK="0x1111" VALUE="{ #switch to B0_P0# 0x04, 0xff, 0x08, 0x00, 0x05, 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, #software reset# #0x01, 0xff, 0x01, 0x01, 0x00,# #Mask IRQ# 0x1a, 0xff, 0xff, 0x00, 0x00, 0x1b, 0xff, 0xff, 0x00, 0x00, 0x1c, 0xff, 0xff, 0x00, 0x00, #Configure Channel# 0x38, 0xff, 0x18, 0x00, 0x00, 0x07, 0xff, 0x00, 0x00, 0x00, 0x06, 0xff, 0x08, 0x00, 0x00, 0x08, 0xff, 0x12, 0x00, 0x00, 0x09, 0xff, 0x00, 0x00, 0x00, 0x0a, 0xff, 0x11, 0x00, 0x00, 0x0b, 0xff, 0x42, 0x00, 0x00, 0x0c, 0xff, 0x40, 0x00, 0x00, #Boost Current Limit# 0x40, 0xff, 0x1a, 0x00, 0x00, #switch to B100_P7# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x64, 0x00, 0x00, 0x00, 0xff, 0x07, 0x00, 0x00, #Class H fix for kink at boost on voltage issue# 0x48, 0xff, 0x09, 0x00, 0x00, 0x49, 0xff, 0x99, 0x00, 0x00, 0x4a, 0xff, 0x99, 0x00, 0x00, 0x4b, 0xff, 0x9a, 0x00, 0x00, 0x4c, 0xff, 0x00, 0x00, 0x00, 0x4d, 0xff, 0x00, 0x00, 0x00, 0x4e, 0xff, 0x00, 0x00, 0x00, 0x4f, 0xff, 0x00, 0x00, 0x00, #switch to B0_P0# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, 0x3b, 0xff, 0x38, 0x00, 0x00, 0x3c, 0xff, 0x3c, 0x00, 0x00, 0x3e, 0xff, 0x30, 0x00, 0x00, #switch to B0_P253# 0x00, 0xff, 0xfd, 0x00, 0x00, #ICN bits changed# 0x0d, 0xff, 0x0d, 0x00, 0x00, 0x32, 0xff, 0x49, 0x00, 0x00, 0x3f, 0xff, 0x21, 0x00, 0x00, 0x19, 0xff, 0x80, 0x00, 0x00, #OTP fix for efficiency# 0x00, 0xff, 0xfd, 0x00, 0x00, 0x0d, 0xff, 0x0d, 0x00, 0x00, 0x5F, 0xff, 0xc1, 0x00, 0x00, #switch to B0_P1# 0x00, 0xff, 0x01, 0x00, 0x00, #thermal foldback disabled# 0x08, 0xff, 0x00, 0x00, 0x00, #switch to B0_P0# 0x04, 0xff, 0x08, 0x00, 0x05, 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, #software reset# #0x01, 0xff, 0x01, 0x01, 0x00,# #Mask IRQ# 0x1a, 0xff, 0xff, 0x00, 0x00, 0x1b, 0xff, 0xff, 0x00, 0x00, 0x1c, 0xff, 0xff, 0x00, 0x00, #Configure Channel# 0x38, 0xff, 0x18, 0x00, 0x00, 0x07, 0xff, 0x00, 0x00, 0x00, 0x06, 0xff, 0x08, 0x00, 0x00, 0x08, 0xff, 0x12, 0x00, 0x00, 0x09, 0xff, 0x01, 0x00, 0x00, 0x0a, 0xff, 0x11, 0x00, 0x00, 0x0b, 0xff, 0x46, 0x00, 0x00, 0x0c, 0xff, 0x44, 0x00, 0x00, 0x3e, 0xff, 0x30, 0x00, 0x00, #Boost Current Limit# 0x40, 0xff, 0x1a, 0x00, 0x00, #switch to B100_P7# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x64, 0x00, 0x00, 0x00, 0xff, 0x07, 0x00, 0x00, #Class H fix for kink at boost on voltage issue# 0x48, 0xff, 0x09, 0x00, 0x00, 0x49, 0xff, 0x99, 0x00, 0x00, 0x4a, 0xff, 0x99, 0x00, 0x00, 0x4b, 0xff, 0x9a, 0x00, 0x00, 0x4c, 0xff, 0x00, 0x00, 0x00, 0x4d, 0xff, 0x00, 0x00, 0x00, 0x4e, 0xff, 0x00, 0x00, 0x00, 0x4f, 0xff, 0x00, 0x00, 0x00, #switch to B0_P0# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, 0x3b, 0xff, 0x38, 0x00, 0x00, 0x3c, 0xff, 0x3c, 0x00, 0x00, #switch to B0_P253# 0x00, 0xff, 0xfd, 0x00, 0x00, #ICN bits changed# 0x0d, 0xff, 0x0d, 0x00, 0x00, 0x32, 0xff, 0x49, 0x00, 0x00, 0x3f, 0xff, 0x21, 0x00, 0x00, 0x19, 0xff, 0x80, 0x00, 0x00, #OTP fix for efficiency# 0x00, 0xff, 0xfd, 0x00, 0x00, 0x0d, 0xff, 0x0d, 0x00, 0x00, 0x5F, 0xff, 0xc1, 0x00, 0x00, #switch to B0_P1# 0x00, 0xff, 0x01, 0x00, 0x00, #thermal foldback disabled# 0x08, 0xff, 0x00, 0x00, 0x00, #switch to B0_P0# 0x04, 0xff, 0x08, 0x00, 0x05, 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, #software reset# #0x01, 0xff, 0x01, 0x01, 0x00,# #Mask IRQ# 0x1a, 0xff, 0xff, 0x00, 0x00, 0x1b, 0xff, 0xff, 0x00, 0x00, 0x1c, 0xff, 0xff, 0x00, 0x00, #Configure Channel# 0x38, 0xff, 0x18, 0x00, 0x00, 0x07, 0xff, 0x00, 0x00, 0x00, 0x06, 0xff, 0x08, 0x00, 0x00, 0x08, 0xff, 0x22, 0x00, 0x00, 0x09, 0xff, 0x20, 0x00, 0x00, 0x0a, 0xff, 0x11, 0x00, 0x00, 0x0b, 0xff, 0x4a, 0x00, 0x00, 0x0c, 0xff, 0x48, 0x00, 0x00, #Boost Current Limit# 0x40, 0xff, 0x1a, 0x00, 0x00, #switch to B100_P7# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x64, 0x00, 0x00, 0x00, 0xff, 0x07, 0x00, 0x00, #Class H fix for kink at boost on voltage issue# 0x48, 0xff, 0x09, 0x00, 0x00, 0x49, 0xff, 0x99, 0x00, 0x00, 0x4a, 0xff, 0x99, 0x00, 0x00, 0x4b, 0xff, 0x9a, 0x00, 0x00, 0x4c, 0xff, 0x00, 0x00, 0x00, 0x4d, 0xff, 0x00, 0x00, 0x00, 0x4e, 0xff, 0x00, 0x00, 0x00, 0x4f, 0xff, 0x00, 0x00, 0x00, #switch to B0_P0# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, 0x3b, 0xff, 0x38, 0x00, 0x00, 0x3c, 0xff, 0x3c, 0x00, 0x00, 0x3e, 0xff, 0x30, 0x00, 0x00, #switch to B0_P253# 0x00, 0xff, 0xfd, 0x00, 0x00, #ICN bits changed# 0x0d, 0xff, 0x0d, 0x00, 0x00, 0x32, 0xff, 0x49, 0x00, 0x00, 0x3f, 0xff, 0x21, 0x00, 0x00, 0x19, 0xff, 0x80, 0x00, 0x00, #OTP fix for efficiency# 0x00, 0xff, 0xfd, 0x00, 0x00, 0x0d, 0xff, 0x0d, 0x00, 0x00, 0x5F, 0xff, 0xc1, 0x00, 0x00, #switch to B0_P1# 0x00, 0xff, 0x01, 0x00, 0x00, #thermal foldback disabled# 0x08, 0xff, 0x00, 0x00, 0x00, #switch to B0_P0# 0x04, 0xff, 0x08, 0x00, 0x05, 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, #software reset# #0x01, 0xff, 0x01, 0x01, 0x00,# #Mask IRQ# 0x1a, 0xff, 0xff, 0x00, 0x00, 0x1b, 0xff, 0xff, 0x00, 0x00, 0x1c, 0xff, 0xff, 0x00, 0x00, #Configure Channel# 0x38, 0xff, 0x18, 0x00, 0x00, 0x07, 0xff, 0x00, 0x00, 0x00, 0x06, 0xff, 0x08, 0x00, 0x00, 0x08, 0xff, 0x22, 0x00, 0x00, 0x09, 0xff, 0x30, 0x00, 0x00, 0x0a, 0xff, 0x11, 0x00, 0x00, 0x0b, 0xff, 0x4e, 0x00, 0x00, 0x0c, 0xff, 0x4c, 0x00, 0x00, #Boost Current Limit# 0x40, 0xff, 0x1a, 0x00, 0x00, #switch to B100_P7# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x64, 0x00, 0x00, 0x00, 0xff, 0x07, 0x00, 0x00, #Class H fix for kink at boost on voltage issue# 0x48, 0xff, 0x09, 0x00, 0x00, 0x49, 0xff, 0x99, 0x00, 0x00, 0x4a, 0xff, 0x99, 0x00, 0x00, 0x4b, 0xff, 0x9a, 0x00, 0x00, 0x4c, 0xff, 0x00, 0x00, 0x00, 0x4d, 0xff, 0x00, 0x00, 0x00, 0x4e, 0xff, 0x00, 0x00, 0x00, 0x4f, 0xff, 0x00, 0x00, 0x00, #switch to B0_P0# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, 0x3b, 0xff, 0x38, 0x00, 0x00, 0x3c, 0xff, 0x3c, 0x00, 0x00, 0x3e, 0xff, 0x30, 0x00, 0x00, #switch to B0_P253# 0x00, 0xff, 0xfd, 0x00, 0x00, #ICN bits changed# 0x0d, 0xff, 0x0d, 0x00, 0x00, 0x32, 0xff, 0x49, 0x00, 0x00, 0x3f, 0xff, 0x21, 0x00, 0x00, 0x19, 0xff, 0x80, 0x00, 0x00, #OTP fix for efficiency# 0x00, 0xff, 0xfd, 0x00, 0x00, 0x0d, 0xff, 0x0d, 0x00, 0x00, 0x5F, 0xff, 0xc1, 0x00, 0x00, #switch to B0_P1# 0x00, 0xff, 0x01, 0x00, 0x00, #thermal foldback disabled# 0x08, 0xff, 0x00, 0x00, 0x00}" /> <SCENCE NAME="POWER_ON_L" CONTROL_MASK="0x1111" VALUE="{ #switch to B0_P0# 0x04, 0xff, 0x08, 0x00, 0x05, 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, #software reset# 0x01, 0xff, 0x01, 0x01, 0x00, #Configure Channel# 0x38, 0xff, 0x18, 0x00, 0x00, 0x07, 0xff, 0x00, 0x00, 0x00, 0x06, 0xff, 0x08, 0x00, 0x00, 0x08, 0xff, 0x12, 0x00, 0x00, 0x09, 0xff, 0x00, 0x00, 0x00, 0x0a, 0xff, 0x11, 0x00, 0x00, 0x0b, 0xff, 0x42, 0x00, 0x00, 0x0c, 0xff, 0x40, 0x00, 0x00, #Boost Current Limit# 0x40, 0xff, 0x1a, 0x00, 0x00, #switch to B100_P7# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x64, 0x00, 0x00, 0x00, 0xff, 0x07, 0x00, 0x00, #Class H fix for kink at boost on voltage issue# 0x48, 0xff, 0x09, 0x00, 0x00, 0x49, 0xff, 0x99, 0x00, 0x00, 0x4a, 0xff, 0x99, 0x00, 0x00, 0x4b, 0xff, 0x9a, 0x00, 0x00, 0x4c, 0xff, 0x00, 0x00, 0x00, 0x4d, 0xff, 0x00, 0x00, 0x00, 0x4e, 0xff, 0x00, 0x00, 0x00, 0x4f, 0xff, 0x00, 0x00, 0x00, #switch to B0_P0# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, 0x3b, 0xff, 0x38, 0x00, 0x00, 0x3c, 0xff, 0x3c, 0x00, 0x00, 0x3e, 0xff, 0x30, 0x00, 0x00, #switch to B0_P253# 0x00, 0xff, 0xfd, 0x00, 0x00, #ICN bits changed# 0x0d, 0xff, 0x0d, 0x00, 0x00, 0x32, 0xff, 0x49, 0x00, 0x00, 0x3f, 0xff, 0x21, 0x00, 0x00, 0x19, 0xff, 0x80, 0x00, 0x00, #OTP fix for efficiency# 0x00, 0xff, 0xfd, 0x00, 0x00, 0x0d, 0xff, 0x0d, 0x00, 0x00, 0x5F, 0xff, 0xc1, 0x00, 0x00, #switch to B0_P1# 0x00, 0xff, 0x01, 0x00, 0x00, #thermal foldback disabled# 0x08, 0xff, 0x00, 0x00, 0x00 #switch to B0_P0# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, #Configure AMP_LEVEL 16dbv# 0x03, 0xff, 0x22, 0x00, 0x00, #Enable bus keeper# 0x0a, 0xff, 0x31, 0x00, 0x00, #power on# 0x02, 0xff, 0x01, 0x01, 0x00, 0x02, 0xff, 0x00, 0x00, 0x00, #Enable IRQ# 0x1a, 0xff, 0xfc, 0x00, 0x00, 0x1b, 0xff, 0xa6, 0x00, 0x00, 0x1c, 0xff, 0xdf, 0x00, 0x00, #switch to B0_P2# 0x00, 0xff, 0x02, 0x00, 0x00, #ICN = -90dBfs# 0x64, 0xff, 0x00, 0x00, 0x00, 0x65, 0xff, 0x01, 0x00, 0x00, 0x66, 0xff, 0x09, 0x00, 0x00, 0x67, 0xff, 0x45, 0x00, 0x00, #switch to B0_P0# 0x04, 0xff, 0x08, 0x00, 0x05, 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, #software reset# 0x01, 0xff, 0x01, 0x01, 0x00, #Configure Channel# 0x38, 0xff, 0x18, 0x00, 0x00, 0x07, 0xff, 0x00, 0x00, 0x00, 0x06, 0xff, 0x08, 0x00, 0x00, 0x08, 0xff, 0x12, 0x00, 0x00, 0x09, 0xff, 0x01, 0x00, 0x00, 0x0a, 0xff, 0x11, 0x00, 0x00, 0x0b, 0xff, 0x46, 0x00, 0x00, 0x0c, 0xff, 0x44, 0x00, 0x00, 0x3e, 0xff, 0x30, 0x00, 0x00, #Boost Current Limit# 0x40, 0xff, 0x1a, 0x00, 0x00, #switch to B100_P7# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x64, 0x00, 0x00, 0x00, 0xff, 0x07, 0x00, 0x00, #Class H fix for kink at boost on voltage issue# 0x48, 0xff, 0x09, 0x00, 0x00, 0x49, 0xff, 0x99, 0x00, 0x00, 0x4a, 0xff, 0x99, 0x00, 0x00, 0x4b, 0xff, 0x9a, 0x00, 0x00, 0x4c, 0xff, 0x00, 0x00, 0x00, 0x4d, 0xff, 0x00, 0x00, 0x00, 0x4e, 0xff, 0x00, 0x00, 0x00, 0x4f, 0xff, 0x00, 0x00, 0x00, #switch to B0_P0# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, 0x3b, 0xff, 0x38, 0x00, 0x00, 0x3c, 0xff, 0x3c, 0x00, 0x00, 0x3e, 0xff, 0x30, 0x00, 0x00, #switch to B0_P253# 0x00, 0xff, 0xfd, 0x00, 0x00, #ICN bits changed# 0x0d, 0xff, 0x0d, 0x00, 0x00, 0x32, 0xff, 0x49, 0x00, 0x00, 0x3f, 0xff, 0x21, 0x00, 0x00, 0x19, 0xff, 0x80, 0x00, 0x00, #OTP fix for efficiency# 0x00, 0xff, 0xfd, 0x00, 0x00, 0x0d, 0xff, 0x0d, 0x00, 0x00, 0x5F, 0xff, 0xc1, 0x00, 0x00, #switch to B0_P1# 0x00, 0xff, 0x01, 0x00, 0x00, #thermal foldback disabled# 0x08, 0xff, 0x00, 0x00, 0x00 #switch to B0_P0# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, #Configure AMP_LEVEL 16dbv# 0x03, 0xff, 0x22, 0x00, 0x00, #Disable bus keeper# 0x0a, 0xff, 0x11, 0x00, 0x00, #power on# 0x02, 0xff, 0x01, 0x01, 0x00, 0x02, 0xff, 0x00, 0x00, 0x00, #Enable IRQ# 0x1a, 0xff, 0xfc, 0x00, 0x00, 0x1b, 0xff, 0xa6, 0x00, 0x00, 0x1c, 0xff, 0xdf, 0x00, 0x00, #switch to B0_P2# 0x00, 0xff, 0x02, 0x00, 0x00, #ICN = -90dBfs# 0x64, 0xff, 0x00, 0x00, 0x00, 0x65, 0xff, 0x01, 0x00, 0x00, 0x66, 0xff, 0x09, 0x00, 0x00, 0x67, 0xff, 0x45, 0x00, 0x00, #switch to B0_P0# 0x04, 0xff, 0x08, 0x00, 0x05, 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, #software reset# 0x01, 0xff, 0x01, 0x01, 0x00, #Configure Channel# 0x38, 0xff, 0x18, 0x00, 0x00, 0x07, 0xff, 0x00, 0x00, 0x00, 0x06, 0xff, 0x08, 0x00, 0x00, 0x08, 0xff, 0x22, 0x00, 0x00, 0x09, 0xff, 0x20, 0x00, 0x00, 0x0a, 0xff, 0x11, 0x00, 0x00, 0x0b, 0xff, 0x4a, 0x00, 0x00, 0x0c, 0xff, 0x48, 0x00, 0x00, #Boost Current Limit# 0x40, 0xff, 0x1a, 0x00, 0x00, #switch to B100_P7# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x64, 0x00, 0x00, 0x00, 0xff, 0x07, 0x00, 0x00, #Class H fix for kink at boost on voltage issue# 0x48, 0xff, 0x09, 0x00, 0x00, 0x49, 0xff, 0x99, 0x00, 0x00, 0x4a, 0xff, 0x99, 0x00, 0x00, 0x4b, 0xff, 0x9a, 0x00, 0x00, 0x4c, 0xff, 0x00, 0x00, 0x00, 0x4d, 0xff, 0x00, 0x00, 0x00, 0x4e, 0xff, 0x00, 0x00, 0x00, 0x4f, 0xff, 0x00, 0x00, 0x00, #switch to B0_P0# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, 0x3b, 0xff, 0x38, 0x00, 0x00, 0x3c, 0xff, 0x3c, 0x00, 0x00, 0x3e, 0xff, 0x30, 0x00, 0x00, #switch to B0_P253# 0x00, 0xff, 0xfd, 0x00, 0x00, #ICN bits changed# 0x0d, 0xff, 0x0d, 0x00, 0x00, 0x32, 0xff, 0x49, 0x00, 0x00, 0x3f, 0xff, 0x21, 0x00, 0x00, 0x19, 0xff, 0x80, 0x00, 0x00, #OTP fix for efficiency# 0x00, 0xff, 0xfd, 0x00, 0x00, 0x0d, 0xff, 0x0d, 0x00, 0x00, 0x5F, 0xff, 0xc1, 0x00, 0x00, #switch to B0_P1# 0x00, 0xff, 0x01, 0x00, 0x00, #thermal foldback disabled# 0x08, 0xff, 0x00, 0x00, 0x00 #switch to B0_P0# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, #Configure AMP_LEVEL 16dbv# 0x03, 0xff, 0x22, 0x00, 0x00, #Disable bus keeper# 0x0a, 0xff, 0x11, 0x00, 0x00, #power on# 0x02, 0xff, 0x01, 0x01, 0x00, 0x02, 0xff, 0x00, 0x00, 0x00, #Enable IRQ# 0x1a, 0xff, 0xfc, 0x00, 0x00, 0x1b, 0xff, 0xa6, 0x00, 0x00, 0x1c, 0xff, 0xdf, 0x00, 0x00, #switch to B0_P2# 0x00, 0xff, 0x02, 0x00, 0x00, #ICN = -90dBfs# 0x64, 0xff, 0x00, 0x00, 0x00, 0x65, 0xff, 0x01, 0x00, 0x00, 0x66, 0xff, 0x09, 0x00, 0x00, 0x67, 0xff, 0x45, 0x00, 0x00, #switch to B0_P0# 0x04, 0xff, 0x08, 0x00, 0x05, 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, #software reset# 0x01, 0xff, 0x01, 0x01, 0x00, #Configure Channel# 0x38, 0xff, 0x18, 0x00, 0x00, 0x07, 0xff, 0x00, 0x00, 0x00, 0x06, 0xff, 0x08, 0x00, 0x00, 0x08, 0xff, 0x22, 0x00, 0x00, 0x09, 0xff, 0x30, 0x00, 0x00, 0x0a, 0xff, 0x11, 0x00, 0x00, 0x0b, 0xff, 0x4e, 0x00, 0x00, 0x0c, 0xff, 0x4c, 0x00, 0x00, #Boost Current Limit# 0x40, 0xff, 0x1a, 0x00, 0x00, #switch to B100_P7# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x64, 0x00, 0x00, 0x00, 0xff, 0x07, 0x00, 0x00, #Class H fix for kink at boost on voltage issue# 0x48, 0xff, 0x09, 0x00, 0x00, 0x49, 0xff, 0x99, 0x00, 0x00, 0x4a, 0xff, 0x99, 0x00, 0x00, 0x4b, 0xff, 0x9a, 0x00, 0x00, 0x4c, 0xff, 0x00, 0x00, 0x00, 0x4d, 0xff, 0x00, 0x00, 0x00, 0x4e, 0xff, 0x00, 0x00, 0x00, 0x4f, 0xff, 0x00, 0x00, 0x00, #switch to B0_P0# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, 0x3b, 0xff, 0x38, 0x00, 0x00, 0x3c, 0xff, 0x3c, 0x00, 0x00, 0x3e, 0xff, 0x30, 0x00, 0x00, #switch to B0_P253# 0x00, 0xff, 0xfd, 0x00, 0x00, #ICN bits changed# 0x0d, 0xff, 0x0d, 0x00, 0x00, 0x32, 0xff, 0x49, 0x00, 0x00, 0x3f, 0xff, 0x21, 0x00, 0x00, 0x19, 0xff, 0x80, 0x00, 0x00, #OTP fix for efficiency# 0x00, 0xff, 0xfd, 0x00, 0x00, 0x0d, 0xff, 0x0d, 0x00, 0x00, 0x5F, 0xff, 0xc1, 0x00, 0x00, #switch to B0_P1# 0x00, 0xff, 0x01, 0x00, 0x00, #thermal foldback disabled# 0x08, 0xff, 0x00, 0x00, 0x00 #switch to B0_P0# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, #Configure AMP_LEVEL 16dbv# 0x03, 0xff, 0x22, 0x00, 0x00, #Disable bus keeper# 0x0a, 0xff, 0x11, 0x00, 0x00, #power on# 0x02, 0xff, 0x01, 0x01, 0x00, 0x02, 0xff, 0x00, 0x00, 0x00, #Enable IRQ# 0x1a, 0xff, 0xfc, 0x00, 0x00, 0x1b, 0xff, 0xa6, 0x00, 0x00, 0x1c, 0xff, 0xdf, 0x00, 0x00, #switch to B0_P2# 0x00, 0xff, 0x02, 0x00, 0x00, #ICN = -90dBfs# 0x64, 0xff, 0x00, 0x00, 0x00, 0x65, 0xff, 0x01, 0x00, 0x00, 0x66, 0xff, 0x09, 0x00, 0x00, 0x67, 0xff, 0x45, 0x00, 0x00}" /> <SCENCE NAME="POWER_OFF_L" CONTROL_MASK="0x1111" VALUE="{ #switch to B0_P0# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, #power down and delay 20ms# 0x02, 0xff, 0x0e, 0x14, 0x00, #Disable bus keeper# 0x0a, 0xff, 0x11, 0x00, 0x00, #switch to B0_P0# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, #power down and delay 20ms# 0x02, 0xff, 0x0e, 0x14, 0x00, #Disable bus keeper# 0x0a, 0xff, 0x11, 0x00, 0x00, #switch to B0_P0# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, #power down and delay 20ms# 0x02, 0xff, 0x0e, 0x14, 0x00, #Disable bus keeper# 0x0a, 0xff, 0x11, 0x00, 0x00, #switch to B0_P0# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, #power down and delay 20ms# 0x02, 0xff, 0x0e, 0x14, 0x00, #Disable bus keeper# 0x0a, 0xff, 0x11, 0x00, 0x00}" /> <SCENCE NAME="VOICE_POWER_ON_L" CONTROL_MASK="0x1111" VALUE="{ #switch to B0_P0# 0x04, 0xff, 0x08, 0x00, 0x05, 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, #software reset# 0x01, 0xff, 0x01, 0x01, 0x00, #Configure Channel# 0x38, 0xff, 0x18, 0x00, 0x00, 0x07, 0xff, 0x00, 0x00, 0x00, 0x06, 0xff, 0x08, 0x00, 0x00, 0x08, 0xff, 0x12, 0x00, 0x00, 0x09, 0xff, 0x00, 0x00, 0x00, 0x0a, 0xff, 0x11, 0x00, 0x00, 0x0b, 0xff, 0x42, 0x00, 0x00, 0x0c, 0xff, 0x40, 0x00, 0x00, #Boost Current Limit# 0x40, 0xff, 0x1a, 0x00, 0x00, #switch to B100_P7# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x64, 0x00, 0x00, 0x00, 0xff, 0x07, 0x00, 0x00, #Class H fix for kink at boost on voltage issue# 0x48, 0xff, 0x09, 0x00, 0x00, 0x49, 0xff, 0x99, 0x00, 0x00, 0x4a, 0xff, 0x99, 0x00, 0x00, 0x4b, 0xff, 0x9a, 0x00, 0x00, 0x4c, 0xff, 0x00, 0x00, 0x00, 0x4d, 0xff, 0x00, 0x00, 0x00, 0x4e, 0xff, 0x00, 0x00, 0x00, 0x4f, 0xff, 0x00, 0x00, 0x00, #switch to B0_P0# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, 0x3b, 0xff, 0x38, 0x00, 0x00, 0x3c, 0xff, 0x3c, 0x00, 0x00, 0x3e, 0xff, 0x30, 0x00, 0x00, #switch to B0_P253# 0x00, 0xff, 0xfd, 0x00, 0x00, #ICN bits changed# 0x0d, 0xff, 0x0d, 0x00, 0x00, 0x32, 0xff, 0x49, 0x00, 0x00, 0x3f, 0xff, 0x21, 0x00, 0x00, 0x19, 0xff, 0x80, 0x00, 0x00, #OTP fix for efficiency# 0x00, 0xff, 0xfd, 0x00, 0x00, 0x0d, 0xff, 0x0d, 0x00, 0x00, 0x5F, 0xff, 0xc1, 0x00, 0x00, #switch to B0_P1# 0x00, 0xff, 0x01, 0x00, 0x00, #thermal foldback disabled# 0x08, 0xff, 0x00, 0x00, 0x00 #switch to B0_P0# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, #Configure AMP_LEVEL 16dbv# 0x03, 0xff, 0x22, 0x00, 0x00, #Enable bus keeper# 0x0a, 0xff, 0x31, 0x00, 0x00, #power on# 0x02, 0xff, 0x01, 0x01, 0x00, 0x02, 0xff, 0x00, 0x00, 0x00, #Enable IRQ# 0x1a, 0xff, 0xfc, 0x00, 0x00, 0x1b, 0xff, 0xa6, 0x00, 0x00, 0x1c, 0xff, 0xdf, 0x00, 0x00, #switch to B0_P2# 0x00, 0xff, 0x02, 0x00, 0x00, #ICN = -90dBfs# 0x64, 0xff, 0x00, 0x00, 0x00, 0x65, 0xff, 0x01, 0x00, 0x00, 0x66, 0xff, 0x09, 0x00, 0x00, 0x67, 0xff, 0x45, 0x00, 0x00, #switch to B0_P0# 0x04, 0xff, 0x08, 0x00, 0x05, 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, #software reset# 0x01, 0xff, 0x01, 0x01, 0x00, #Configure Channel# 0x38, 0xff, 0x18, 0x00, 0x00, 0x07, 0xff, 0x00, 0x00, 0x00, 0x06, 0xff, 0x08, 0x00, 0x00, 0x08, 0xff, 0x12, 0x00, 0x00, 0x09, 0xff, 0x01, 0x00, 0x00, 0x0a, 0xff, 0x11, 0x00, 0x00, 0x0b, 0xff, 0x46, 0x00, 0x00, 0x0c, 0xff, 0x44, 0x00, 0x00, 0x3e, 0xff, 0x30, 0x00, 0x00, #Boost Current Limit# 0x40, 0xff, 0x1a, 0x00, 0x00, #switch to B100_P7# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x64, 0x00, 0x00, 0x00, 0xff, 0x07, 0x00, 0x00, #Class H fix for kink at boost on voltage issue# 0x48, 0xff, 0x09, 0x00, 0x00, 0x49, 0xff, 0x99, 0x00, 0x00, 0x4a, 0xff, 0x99, 0x00, 0x00, 0x4b, 0xff, 0x9a, 0x00, 0x00, 0x4c, 0xff, 0x00, 0x00, 0x00, 0x4d, 0xff, 0x00, 0x00, 0x00, 0x4e, 0xff, 0x00, 0x00, 0x00, 0x4f, 0xff, 0x00, 0x00, 0x00, #switch to B0_P0# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, 0x3b, 0xff, 0x38, 0x00, 0x00, 0x3c, 0xff, 0x3c, 0x00, 0x00, 0x3e, 0xff, 0x30, 0x00, 0x00, #switch to B0_P253# 0x00, 0xff, 0xfd, 0x00, 0x00, #ICN bits changed# 0x0d, 0xff, 0x0d, 0x00, 0x00, 0x32, 0xff, 0x49, 0x00, 0x00, 0x3f, 0xff, 0x21, 0x00, 0x00, 0x19, 0xff, 0x80, 0x00, 0x00, #OTP fix for efficiency# 0x00, 0xff, 0xfd, 0x00, 0x00, 0x0d, 0xff, 0x0d, 0x00, 0x00, 0x5F, 0xff, 0xc1, 0x00, 0x00, #switch to B0_P1# 0x00, 0xff, 0x01, 0x00, 0x00, #thermal foldback disabled# 0x08, 0xff, 0x00, 0x00, 0x00 #switch to B0_P0# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, #Configure AMP_LEVEL 16dbv# 0x03, 0xff, 0x22, 0x00, 0x00, #Disable bus keeper# 0x0a, 0xff, 0x11, 0x00, 0x00, #power on# 0x02, 0xff, 0x01, 0x01, 0x00, 0x02, 0xff, 0x00, 0x00, 0x00, #Enable IRQ# 0x1a, 0xff, 0xfc, 0x00, 0x00, 0x1b, 0xff, 0xa6, 0x00, 0x00, 0x1c, 0xff, 0xdf, 0x00, 0x00, #switch to B0_P2# 0x00, 0xff, 0x02, 0x00, 0x00, #ICN = -90dBfs# 0x64, 0xff, 0x00, 0x00, 0x00, 0x65, 0xff, 0x01, 0x00, 0x00, 0x66, 0xff, 0x09, 0x00, 0x00, 0x67, 0xff, 0x45, 0x00, 0x00, #switch to B0_P0# 0x04, 0xff, 0x08, 0x00, 0x05, 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, #software reset# 0x01, 0xff, 0x01, 0x01, 0x00, #Configure Channel# 0x38, 0xff, 0x18, 0x00, 0x00, 0x07, 0xff, 0x00, 0x00, 0x00, 0x06, 0xff, 0x08, 0x00, 0x00, 0x08, 0xff, 0x22, 0x00, 0x00, 0x09, 0xff, 0x20, 0x00, 0x00, 0x0a, 0xff, 0x11, 0x00, 0x00, 0x0b, 0xff, 0x4a, 0x00, 0x00, 0x0c, 0xff, 0x48, 0x00, 0x00, #Boost Current Limit# 0x40, 0xff, 0x1a, 0x00, 0x00, #switch to B100_P7# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x64, 0x00, 0x00, 0x00, 0xff, 0x07, 0x00, 0x00, #Class H fix for kink at boost on voltage issue# 0x48, 0xff, 0x09, 0x00, 0x00, 0x49, 0xff, 0x99, 0x00, 0x00, 0x4a, 0xff, 0x99, 0x00, 0x00, 0x4b, 0xff, 0x9a, 0x00, 0x00, 0x4c, 0xff, 0x00, 0x00, 0x00, 0x4d, 0xff, 0x00, 0x00, 0x00, 0x4e, 0xff, 0x00, 0x00, 0x00, 0x4f, 0xff, 0x00, 0x00, 0x00, #switch to B0_P0# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, 0x3b, 0xff, 0x38, 0x00, 0x00, 0x3c, 0xff, 0x3c, 0x00, 0x00, 0x3e, 0xff, 0x30, 0x00, 0x00, #switch to B0_P253# 0x00, 0xff, 0xfd, 0x00, 0x00, #ICN bits changed# 0x0d, 0xff, 0x0d, 0x00, 0x00, 0x32, 0xff, 0x49, 0x00, 0x00, 0x3f, 0xff, 0x21, 0x00, 0x00, 0x19, 0xff, 0x80, 0x00, 0x00, #OTP fix for efficiency# 0x00, 0xff, 0xfd, 0x00, 0x00, 0x0d, 0xff, 0x0d, 0x00, 0x00, 0x5F, 0xff, 0xc1, 0x00, 0x00, #switch to B0_P1# 0x00, 0xff, 0x01, 0x00, 0x00, #thermal foldback disabled# 0x08, 0xff, 0x00, 0x00, 0x00 #switch to B0_P0# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, #Configure AMP_LEVEL 16dbv# 0x03, 0xff, 0x22, 0x00, 0x00, #Disable bus keeper# 0x0a, 0xff, 0x11, 0x00, 0x00, #power on# 0x02, 0xff, 0x01, 0x01, 0x00, 0x02, 0xff, 0x00, 0x00, 0x00, #Enable IRQ# 0x1a, 0xff, 0xfc, 0x00, 0x00, 0x1b, 0xff, 0xa6, 0x00, 0x00, 0x1c, 0xff, 0xdf, 0x00, 0x00, #switch to B0_P2# 0x00, 0xff, 0x02, 0x00, 0x00, #ICN = -90dBfs# 0x64, 0xff, 0x00, 0x00, 0x00, 0x65, 0xff, 0x01, 0x00, 0x00, 0x66, 0xff, 0x09, 0x00, 0x00, 0x67, 0xff, 0x45, 0x00, 0x00, #switch to B0_P0# 0x04, 0xff, 0x08, 0x00, 0x05, 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, #software reset# 0x01, 0xff, 0x01, 0x01, 0x00, #Configure Channel# 0x38, 0xff, 0x18, 0x00, 0x00, 0x07, 0xff, 0x00, 0x00, 0x00, 0x06, 0xff, 0x08, 0x00, 0x00, 0x08, 0xff, 0x22, 0x00, 0x00, 0x09, 0xff, 0x30, 0x00, 0x00, 0x0a, 0xff, 0x11, 0x00, 0x00, 0x0b, 0xff, 0x4e, 0x00, 0x00, 0x0c, 0xff, 0x4c, 0x00, 0x00, #Boost Current Limit# 0x40, 0xff, 0x1a, 0x00, 0x00, #switch to B100_P7# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x64, 0x00, 0x00, 0x00, 0xff, 0x07, 0x00, 0x00, #Class H fix for kink at boost on voltage issue# 0x48, 0xff, 0x09, 0x00, 0x00, 0x49, 0xff, 0x99, 0x00, 0x00, 0x4a, 0xff, 0x99, 0x00, 0x00, 0x4b, 0xff, 0x9a, 0x00, 0x00, 0x4c, 0xff, 0x00, 0x00, 0x00, 0x4d, 0xff, 0x00, 0x00, 0x00, 0x4e, 0xff, 0x00, 0x00, 0x00, 0x4f, 0xff, 0x00, 0x00, 0x00, #switch to B0_P0# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, 0x3b, 0xff, 0x38, 0x00, 0x00, 0x3c, 0xff, 0x3c, 0x00, 0x00, 0x3e, 0xff, 0x30, 0x00, 0x00, #switch to B0_P253# 0x00, 0xff, 0xfd, 0x00, 0x00, #ICN bits changed# 0x0d, 0xff, 0x0d, 0x00, 0x00, 0x32, 0xff, 0x49, 0x00, 0x00, 0x3f, 0xff, 0x21, 0x00, 0x00, 0x19, 0xff, 0x80, 0x00, 0x00, #OTP fix for efficiency# 0x00, 0xff, 0xfd, 0x00, 0x00, 0x0d, 0xff, 0x0d, 0x00, 0x00, 0x5F, 0xff, 0xc1, 0x00, 0x00, #switch to B0_P1# 0x00, 0xff, 0x01, 0x00, 0x00, #thermal foldback disabled# 0x08, 0xff, 0x00, 0x00, 0x00 #switch to B0_P0# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, #Configure AMP_LEVEL 16dbv# 0x03, 0xff, 0x22, 0x00, 0x00, #Disable bus keeper# 0x0a, 0xff, 0x11, 0x00, 0x00, #power on# 0x02, 0xff, 0x01, 0x01, 0x00, 0x02, 0xff, 0x00, 0x00, 0x00, #Enable IRQ# 0x1a, 0xff, 0xfc, 0x00, 0x00, 0x1b, 0xff, 0xa6, 0x00, 0x00, 0x1c, 0xff, 0xdf, 0x00, 0x00, #switch to B0_P2# 0x00, 0xff, 0x02, 0x00, 0x00, #ICN = -90dBfs# 0x64, 0xff, 0x00, 0x00, 0x00, 0x65, 0xff, 0x01, 0x00, 0x00, 0x66, 0xff, 0x09, 0x00, 0x00, 0x67, 0xff, 0x45, 0x00, 0x00}" /> <SCENCE NAME="VOICE_POWER_OFF_L" CONTROL_MASK="0x1111" VALUE="{ #switch to B0_P0# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, #power down and delay 20ms# 0x02, 0xff, 0x0e, 0x14, 0x00, #Disable bus keeper# 0x0a, 0xff, 0x11, 0x00, 0x00, #switch to B0_P0# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, #power down and delay 20ms# 0x02, 0xff, 0x0e, 0x14, 0x00, #Disable bus keeper# 0x0a, 0xff, 0x11, 0x00, 0x00, #switch to B0_P0# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, #power down and delay 20ms# 0x02, 0xff, 0x0e, 0x14, 0x00, #Disable bus keeper# 0x0a, 0xff, 0x11, 0x00, 0x00, #switch to B0_P0# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, #power down and delay 20ms# 0x02, 0xff, 0x0e, 0x14, 0x00, #Disable bus keeper# 0x0a, 0xff, 0x11, 0x00, 0x00}" /> <!--for mmi test --> <SCENCE NAME="MMI_POWER_ON_SPK_ALL" CONTROL_MASK="0x1111" VALUE="{ #switch to B0_P0# 0x00, 0xff, 0x01, 0x00, 0x00, #thermal foldback disabled# 0x08, 0xff, 0x00, 0x00, 0x00 #switch to B0_P0# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, #Configure AMP_LEVEL 15dbv# 0x03, 0xff, 0x1c, 0x00, 0x00, #Enable bus keeper# 0x0a, 0xff, 0x31, 0x00, 0x00, #power on# 0x02, 0xff, 0x01, 0x01, 0x00, 0x02, 0xff, 0x00, 0x00, 0x00, #Enable IRQ# 0x1a, 0xff, 0xfc, 0x00, 0x00, 0x1b, 0xff, 0xa6, 0x00, 0x00, 0x1c, 0xff, 0xdf, 0x00, 0x00, #switch to B0_P2# 0x00, 0xff, 0x02, 0x00, 0x00, #ICN = -90dBfs# 0x64, 0xff, 0x00, 0x00, 0x00, 0x65, 0xff, 0x01, 0x00, 0x00, 0x66, 0xff, 0x09, 0x00, 0x00, 0x67, 0xff, 0x45, 0x00, 0x00, #switch to B0_P0# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, #Configure AMP_LEVEL 15dbv# 0x03, 0xff, 0x1c, 0x00, 0x00, #Disable bus keeper# 0x0a, 0xff, 0x11, 0x00, 0x00, #power on# 0x02, 0xff, 0x01, 0x01, 0x00, 0x02, 0xff, 0x00, 0x00, 0x00, #Enable IRQ# 0x1a, 0xff, 0xfc, 0x00, 0x00, 0x1b, 0xff, 0xa6, 0x00, 0x00, 0x1c, 0xff, 0xdf, 0x00, 0x00, #switch to B0_P2# 0x00, 0xff, 0x02, 0x00, 0x00, #ICN = -90dBfs# 0x64, 0xff, 0x00, 0x00, 0x00, 0x65, 0xff, 0x01, 0x00, 0x00, 0x66, 0xff, 0x09, 0x00, 0x00, 0x67, 0xff, 0x45, 0x00, 0x00, #switch to B0_P1# 0x00, 0xff, 0x01, 0x00, 0x00, #thermal foldback disabled# 0x08, 0xff, 0x00, 0x00, 0x00 #switch to B0_P0# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, #Configure AMP_LEVEL 15dbv# 0x03, 0xff, 0x1c, 0x00, 0x00, #Disable bus keeper# 0x0a, 0xff, 0x11, 0x00, 0x00, #power on# 0x02, 0xff, 0x01, 0x01, 0x00, 0x02, 0xff, 0x00, 0x00, 0x00, #Enable IRQ# 0x1a, 0xff, 0xfc, 0x00, 0x00, 0x1b, 0xff, 0xa6, 0x00, 0x00, 0x1c, 0xff, 0xdf, 0x00, 0x00, #switch to B0_P2# 0x00, 0xff, 0x02, 0x00, 0x00, #ICN = -90dBfs# 0x64, 0xff, 0x00, 0x00, 0x00, 0x65, 0xff, 0x01, 0x00, 0x00, 0x66, 0xff, 0x09, 0x00, 0x00, 0x67, 0xff, 0x45, 0x00, 0x00, #switch to B0_P0# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, #Configure AMP_LEVEL 15dbv# 0x03, 0xff, 0x1c, 0x00, 0x00, #Disable bus keeper# 0x0a, 0xff, 0x11, 0x00, 0x00, #power on# 0x02, 0xff, 0x01, 0x01, 0x00, 0x02, 0xff, 0x00, 0x00, 0x00, #Enable IRQ# 0x1a, 0xff, 0xfc, 0x00, 0x00, 0x1b, 0xff, 0xa6, 0x00, 0x00, 0x1c, 0xff, 0xdf, 0x00, 0x00, #switch to B0_P2# 0x00, 0xff, 0x02, 0x00, 0x00, #ICN = -90dBfs# 0x64, 0xff, 0x00, 0x00, 0x00, 0x65, 0xff, 0x01, 0x00, 0x00, 0x66, 0xff, 0x09, 0x00, 0x00, 0x67, 0xff, 0x45, 0x00, 0x00}" /> <SCENCE NAME="MMI_POWER_ON_PRI_L" CONTROL_MASK="0x0001" VALUE="{ #switch to B0_P0# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, #Configure AMP_LEVEL 15dbv# 0x03, 0xff, 0x1c, 0x00, 0x00, #power on# 0x02, 0xff, 0x01, 0x01, 0x00, 0x02, 0xff, 0x00, 0x00, 0x00, #switch to B0_P2# 0x00, 0xff, 0x02, 0x00, 0x00, #ICN = -90dBfs# 0x64, 0xff, 0x00, 0x00, 0x00, 0x65, 0xff, 0x01, 0x00, 0x00, 0x66, 0xff, 0x09, 0x00, 0x00, 0x67, 0xff, 0x45, 0x00, 0x00}" /> <SCENCE NAME="MMI_POWER_ON_PRI_R" CONTROL_MASK="0x0100" VALUE="{ #switch to B0_P0# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, #Configure AMP_LEVEL 15dbv# 0x03, 0xff, 0x1c, 0x00, 0x00, #power on# 0x02, 0xff, 0x01, 0x01, 0x00, 0x02, 0xff, 0x00, 0x00, 0x00, #switch to B0_P2# 0x00, 0xff, 0x02, 0x00, 0x00, #ICN = -90dBfs# 0x64, 0xff, 0x00, 0x00, 0x00, 0x65, 0xff, 0x01, 0x00, 0x00, 0x66, 0xff, 0x09, 0x00, 0x00, 0x67, 0xff, 0x45, 0x00, 0x00}" /> <SCENCE NAME="MMI_POWER_ON_SEC_L" CONTROL_MASK="0x0010" VALUE="{ #switch to B0_P0# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, #Configure AMP_LEVEL 15dbv# 0x03, 0xff, 0x1c, 0x00, 0x00, #power on# 0x02, 0xff, 0x01, 0x01, 0x00, 0x02, 0xff, 0x00, 0x00, 0x00, #switch to B0_P2# 0x00, 0xff, 0x02, 0x00, 0x00, #ICN = -90dBfs# 0x64, 0xff, 0x00, 0x00, 0x00, 0x65, 0xff, 0x01, 0x00, 0x00, 0x66, 0xff, 0x09, 0x00, 0x00, 0x67, 0xff, 0x45, 0x00, 0x00}" /> <SCENCE NAME="MMI_POWER_ON_SEC_R" CONTROL_MASK="0x1000" VALUE="{ #switch to B0_P0# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, #Configure AMP_LEVEL 15dbv# 0x03, 0xff, 0x1c, 0x00, 0x00, #power on# 0x02, 0xff, 0x01, 0x01, 0x00, 0x02, 0xff, 0x00, 0x00, 0x00, #switch to B0_P2# 0x00, 0xff, 0x02, 0x00, 0x00, #ICN = -90dBfs# 0x64, 0xff, 0x00, 0x00, 0x00, 0x65, 0xff, 0x01, 0x00, 0x00, 0x66, 0xff, 0x09, 0x00, 0x00, 0x67, 0xff, 0x45, 0x00, 0x00}" /> <SCENCE NAME="AT_POWER_ON_PRI_L" CONTROL_MASK="0x0001" VALUE="{ #switch to B0_P0# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, #Configure AMP_LEVEL 10dbv# 0x03, 0xff, 0x08, 0x00, 0x00, #power on# 0x02, 0xff, 0x01, 0x01, 0x00, 0x02, 0xff, 0x00, 0x00, 0x00, #switch to B0_P2# 0x00, 0xff, 0x02, 0x00, 0x00, #ICN = -90dBfs# 0x64, 0xff, 0x00, 0x00, 0x00, 0x65, 0xff, 0x01, 0x00, 0x00, 0x66, 0xff, 0x09, 0x00, 0x00, 0x67, 0xff, 0x45, 0x00, 0x00}" /> <SCENCE NAME="AT_POWER_ON_PRI_R" CONTROL_MASK="0x0100" VALUE="{ #switch to B0_P0# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, #Configure AMP_LEVEL 10dbv# 0x03, 0xff, 0x08, 0x00, 0x00, #power on# 0x02, 0xff, 0x01, 0x01, 0x00, 0x02, 0xff, 0x00, 0x00, 0x00, #switch to B0_P2# 0x00, 0xff, 0x02, 0x00, 0x00, #ICN = -90dBfs# 0x64, 0xff, 0x00, 0x00, 0x00, 0x65, 0xff, 0x01, 0x00, 0x00, 0x66, 0xff, 0x09, 0x00, 0x00, 0x67, 0xff, 0x45, 0x00, 0x00}" /> <SCENCE NAME="AT_POWER_ON_SEC_L" CONTROL_MASK="0x0010" VALUE="{ #switch to B0_P0# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, #Configure AMP_LEVEL 10dbv# 0x03, 0xff, 0x08, 0x00, 0x00, #power on# 0x02, 0xff, 0x01, 0x01, 0x00, 0x02, 0xff, 0x00, 0x00, 0x00, #switch to B0_P2# 0x00, 0xff, 0x02, 0x00, 0x00, #ICN = -90dBfs# 0x64, 0xff, 0x00, 0x00, 0x00, 0x65, 0xff, 0x01, 0x00, 0x00, 0x66, 0xff, 0x09, 0x00, 0x00, 0x67, 0xff, 0x45, 0x00, 0x00}" /> <SCENCE NAME="AT_POWER_ON_SEC_R" CONTROL_MASK="0x1000" VALUE="{ #switch to B0_P0# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, #Configure AMP_LEVEL 10dbv# 0x03, 0xff, 0x08, 0x00, 0x00, #power on# 0x02, 0xff, 0x01, 0x01, 0x00, 0x02, 0xff, 0x00, 0x00, 0x00, #switch to B0_P2# 0x00, 0xff, 0x02, 0x00, 0x00, #ICN = -90dBfs# 0x64, 0xff, 0x00, 0x00, 0x00, 0x65, 0xff, 0x01, 0x00, 0x00, 0x66, 0xff, 0x09, 0x00, 0x00, 0x67, 0xff, 0x45, 0x00, 0x00}" /> <SCENCE NAME="AT_POWER_ON_SPK_ALL" CONTROL_MASK="0x1111" VALUE="{ #switch to B0_P0# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, #Configure AMP_LEVEL 14dbv# 0x03, 0xff, 0x18, 0x00, 0x00, #Enable bus keeper# 0x0a, 0xff, 0x31, 0x00, 0x00, #power on# 0x02, 0xff, 0x01, 0x01, 0x00, 0x02, 0xff, 0x00, 0x00, 0x00, #Enable IRQ# 0x1a, 0xff, 0xfc, 0x00, 0x00, 0x1b, 0xff, 0xa6, 0x00, 0x00, 0x1c, 0xff, 0xdf, 0x00, 0x00, #switch to B0_P2# 0x00, 0xff, 0x02, 0x00, 0x00, #ICN = -90dBfs# 0x64, 0xff, 0x00, 0x00, 0x00, 0x65, 0xff, 0x01, 0x00, 0x00, 0x66, 0xff, 0x09, 0x00, 0x00, 0x67, 0xff, 0x45, 0x00, 0x00, #switch to B0_P0# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, #Configure AMP_LEVEL 14dbv# 0x03, 0xff, 0x18, 0x00, 0x00, #Disable bus keeper# 0x0a, 0xff, 0x11, 0x00, 0x00, #power on# 0x02, 0xff, 0x01, 0x01, 0x00, 0x02, 0xff, 0x00, 0x00, 0x00, #Enable IRQ# 0x1a, 0xff, 0xfc, 0x00, 0x00, 0x1b, 0xff, 0xa6, 0x00, 0x00, 0x1c, 0xff, 0xdf, 0x00, 0x00, #switch to B0_P2# 0x00, 0xff, 0x02, 0x00, 0x00, #ICN = -90dBfs# 0x64, 0xff, 0x00, 0x00, 0x00, 0x65, 0xff, 0x01, 0x00, 0x00, 0x66, 0xff, 0x09, 0x00, 0x00, 0x67, 0xff, 0x45, 0x00, 0x00, #switch to B0_P0# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, #Configure AMP_LEVEL 14dbv# 0x03, 0xff, 0x18, 0x00, 0x00, #Disable bus keeper# 0x0a, 0xff, 0x11, 0x00, 0x00, #power on# 0x02, 0xff, 0x01, 0x01, 0x00, 0x02, 0xff, 0x00, 0x00, 0x00, #Enable IRQ# 0x1a, 0xff, 0xfc, 0x00, 0x00, 0x1b, 0xff, 0xa6, 0x00, 0x00, 0x1c, 0xff, 0xdf, 0x00, 0x00, #switch to B0_P2# 0x00, 0xff, 0x02, 0x00, 0x00, #ICN = -90dBfs# 0x64, 0xff, 0x00, 0x00, 0x00, 0x65, 0xff, 0x01, 0x00, 0x00, 0x66, 0xff, 0x09, 0x00, 0x00, 0x67, 0xff, 0x45, 0x00, 0x00, #switch to B0_P0# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, #Configure AMP_LEVEL 14dbv# 0x03, 0xff, 0x18, 0x00, 0x00, #Disable bus keeper# 0x0a, 0xff, 0x11, 0x00, 0x00, #power on# 0x02, 0xff, 0x01, 0x01, 0x00, 0x02, 0xff, 0x00, 0x00, 0x00, #Enable IRQ# 0x1a, 0xff, 0xfc, 0x00, 0x00, 0x1b, 0xff, 0xa6, 0x00, 0x00, 0x1c, 0xff, 0xdf, 0x00, 0x00, #switch to B0_P2# 0x00, 0xff, 0x02, 0x00, 0x00, #ICN = -90dBfs# 0x64, 0xff, 0x00, 0x00, 0x00, 0x65, 0xff, 0x01, 0x00, 0x00, 0x66, 0xff, 0x09, 0x00, 0x00, 0x67, 0xff, 0x45, 0x00, 0x00}" /> <SCENCE NAME="MMI_POWER_ON_SPK_RCV" CONTROL_MASK="0x1111" VALUE="{ #switch to B0_P0# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, #Configure AMP_LEVEL 17dbv# 0x03, 0xff, 0x24, 0x00, 0x00, #power on# 0x02, 0xff, 0x01, 0x01, 0x00, 0x02, 0xff, 0x00, 0x00, 0x00, #switch to B0_P2# 0x00, 0xff, 0x02, 0x00, 0x00, #ICN = -90dBfs# 0x64, 0xff, 0x00, 0x00, 0x00, 0x65, 0xff, 0x01, 0x00, 0x00, 0x66, 0xff, 0x09, 0x00, 0x00, 0x67, 0xff, 0x45, 0x00, 0x00, #switch to B0_P0# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, #Configure AMP_LEVEL 17dbv# 0x03, 0xff, 0x24, 0x00, 0x00, #power on# 0x02, 0xff, 0x0e, 0x01, 0x00, 0x02, 0xff, 0x0e, 0x00, 0x00, #switch to B0_P2# 0x00, 0xff, 0x02, 0x00, 0x00, #ICN = -90dBfs# 0x64, 0xff, 0x00, 0x00, 0x00, 0x65, 0xff, 0x01, 0x00, 0x00, 0x66, 0xff, 0x09, 0x00, 0x00, 0x67, 0xff, 0x45, 0x00, 0x00, #switch to B0_P0# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, #Configure AMP_LEVEL 17dbv# 0x03, 0xff, 0x24, 0x00, 0x00, #power on# 0x02, 0xff, 0x0e, 0x01, 0x00, 0x02, 0xff, 0x0e, 0x00, 0x00, #switch to B0_P2# 0x00, 0xff, 0x02, 0x00, 0x00, #ICN = -90dBfs# 0x64, 0xff, 0x00, 0x00, 0x00, 0x65, 0xff, 0x01, 0x00, 0x00, 0x66, 0xff, 0x09, 0x00, 0x00, 0x67, 0xff, 0x45, 0x00, 0x00, #switch to B0_P0# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, #Configure AMP_LEVEL 17dbv# 0x03, 0xff, 0x24, 0x00, 0x00, #power on# 0x02, 0xff, 0x0e, 0x01, 0x00, 0x02, 0xff, 0x0e, 0x00, 0x00, #switch to B0_P2# 0x00, 0xff, 0x02, 0x00, 0x00, #ICN = -90dBfs# 0x64, 0xff, 0x00, 0x00, 0x00, 0x65, 0xff, 0x01, 0x00, 0x00, 0x66, 0xff, 0x09, 0x00, 0x00, 0x67, 0xff, 0x45, 0x00, 0x00}" /> <SCENCE NAME="MMI_POWER_OFF" CONTROL_MASK="0x1111" VALUE="{ #switch to B0_P0# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, #power down and delay 20ms# 0x02, 0xff, 0x0e, 0x14, 0x00, #switch to B0_P0# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, #power down and delay 20ms# 0x02, 0xff, 0x0e, 0x14, 0x00, #switch to B0_P0# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, #power down and delay 20ms# 0x02, 0xff, 0x0e, 0x14, 0x00, #switch to B0_P0# 0x00, 0xff, 0x00, 0x00, 0x00, 0x7f, 0xff, 0x00, 0x00, 0x00, #power down and delay 20ms# 0x02, 0xff, 0x0e, 0x14, 0x00}" /> </PA_STATUS> </NV_CATEGORY>
