Part Number: LM833
We use LM833 to amplify the audio signal with VCC+/VCC- at +18/-18V.
On datasheet,±18V is the recommended operating condition,but also the maximum VCC is ±18V,like below.
So we are worry about our application,is LM833 can work normally at ±18V,and safe?
Hi Lifang,
Thank you for your post. I can help you.
You may follow the Recommended Operating Conditions and supply +/-18V.
-Tamara
-Tamara Alani Learn more about IAs here.
In reply to Tamara M Alani:
Hi Tamara,
Is the Maximun Rating VCC wrong?It's usually higher than Recommended Operating VCC.
In reply to lifang lu:
Good observation. I will look into this with the product definition team and update the datasheet if necessary. Circling back to your initial question, +/-18V on this device is okay for operation.
Thanks a lot.
Looking forward to your early reply!
