Part Number: TAS2563
Hi Team,
Customer want to check if TAS2563 is able to using the DMIC record and play music at the sample time? If it's OK, how to configure this. Could you help check on this?
Thanks and Best Regards,
Will
Hi Team,
Will
Hi Will,
We're currently working on firmware update for TAS2563 to support DMIC record functionality. At this moment the device can configure the PDM interface as Master or Slave, send/receive PDMCLK so that the digital mics can send PDMD.
However the sampling, decimation and re-sampling to send PDMD back through SDOUT is still under development and testing. The plan is to have record and playback simultaneously.
I'll reach out to you once we have details on the release of this update.
Best regards.
-Ivan Salazar
Applications Engineer - Low Power Audio & Actuators
