I have been looking into PCM9211 to use with HDMI ARC port. The goal is to transfer stereo channel audio and nothing related to multi-channel data.
But it's not a direct connection from the ARC port to PCM9211, but there is a USB-C bridge in between.
Up to the HDMI version 1.4b , ALT mode for USB-C is available and USB-C's SBU pins can be used for the ARC HEAC+ and HEAC- pins.
So I'm trying to get HEAC+ data from the HDMI ARC port through USB-C SBU lines and to the RXIN pin of the PCM9211.
I have attached my very rough schematics and I want to check if this is possible.
Thank you
