Other Parts Discussed in Thread: TLV320AIC3111,
Hi
I am using TLV320AIC3111 CODEC IC for audio filtering,Block diagram is as follows
As mentioned in block diagram I am using SAI peripheral connectivity for audio data transmission, Master clock, frame clock and bit clock is generated by controller.
details as follows
MCLK- 2.048 MHz
BCLK- 8 KHz
WCLK- 512 KHz
As mentioned in above dia I am sending data over USB, this sound data has an metallic sound.
I am looking for solution to remove this extraa metallic sound.
