Other Parts Discussed in Thread: OPA4134, PCM5242, PCM5142, OPA1656
I'm working on a hobby oriented project and i bought 2 PCM5252s for the audio DAC part.
They will be driven by an XMC4500 uC.
I aim to make a DSP capable sound-card.Part of the filters will be done in the PCM5252(I hope) and another part on the XMC4500(Cortex M4).
I'll use a filter like the ones described in SBAA322 or SBAA001 for the output.
2xOPA4134 will be the 8 OPAMPs necessary(2 for the differential to single ended conversion and 6 for the filters).
I simulated the filter described in SBA001 and it works with the OPA4134.
The only problem i have is related to PCM5252 DSP programming.
While similar with PCM5242 and price wise nearly the same i opted for them since they integrated SmartAMP functionality that seemed nice to try out.I didn't know i might hit a programming deadlock regarding the availability of the development software.
I'd like to know if i can program the PCM5252 as a hobbyist using the TI's tools since i read in the forum only PCM5242 is supported publicly.I don't mind losing on the Smart Amp functionality as long as i can use it as a PCM5242.
Also to what extent are PCM5252 and PCM5242 code compatible?
I don't mind 'hand writing' some instructions ,but doing all the filters 'by hand' is not really nice.
