Today I received the EVM for TPA6304Q1. My thanks to TI'er Adam Daluga for his help in obtaining it.
I noticed that the EVM came without documentation and driver, but I requested these items online as directed by a package-stuffer in the carton.
Our application for the TPA6304Q1 is a bit different than TI intended. We are not using it to amplify audio, but instead to amplify complex waveforms to create 100+ ampere currents delivered via current transformers. This is a test and measurement application that will require me to learn a lot of analog lessons about the TPA6304 before I hand the design over to the guys who write our code..
I have almost finished with my PCB lay-out to accept the TPA6304. It was easy to design because this part has heritage to the TA5414 that we've been prototyping with.
I hoped to simply duplicate onto my TPA6304 prototype board the USB-to-I2C converter that you used on its EVM. But I see that this will be quite difficult because of the customized 128-pin XMOS part.
Is it true that this XMOS part (and its custom firmware) is out of reach to designers like me? Is a possible workaround to sever the I2C connection between the XMOS part and the TPA6304 and export these I2C signals to my prototype board?
This is going to be a messy prototype.
Thanks in advance for your help on this.
Jim Olson
Indianapolis, IN US
