After power on, VR_DIG output 0.64V,AVDD and GVDD have no output, so I2C communication cann ot be achieved. Power on after power off 6s, t est 10 times for 10abnormalities;
Power on af ter power off 30s,test 10 times and 2 times a bnormal; The normal veneer is tested above wit hout any abnormality; ABA swap, failed follow the failed parts.
The DUT was pass the function and aging test, but It was found in the customer in normal use.
2. pull down /PDN when in Uboot mode, and then pull up after system startup finish, the /PDN at least pull down 20s,and then the VR_DIG output was normal when /PDN was pull up
3. We want to check the chip whether or nor have a issue?
