• Resolved
PCM1795: Demonstration software for DEM-PCM1795
Intellectual 305 points
Part Number: PCM1795
can DEM-PCM1796 and DEM-PCM1795 use the same software?
If available, please could you provide DEM1796.exe, DEM1796.ini, Vbrjp200.dll, Ver.dll and Inpout.dll.
If not available, please could you provide demonstration software for DEM-PCM1795.
The EVM User's Guide says: "Demonstration software is provided to control the PCM1796 / DSD1796 internal register using a PC that is running the Microsoft® Windows® operating system. This software uses a printer cable to connect the PC to the DEM-PCM / DSD1796 connector CN003."(DEM-PCM1795 User' Guide, p10, 1.9:Demonstration Software).
Nishie
  • Hi Nishie,
    I am checking if the software is still available on our servers.  The EVM has been end-of-life'd for some time now, so it is possible the software is no longer available.  In addition, the software is likely only compatible with Windows XP.  I have seen some customers successfully use similar software with Windows 7, but I am not sure of the conditions they were able to get it to function.
    I will let you know by tomorrow.
    Paul
  • In reply to Paul_Frost:
    slac245.zip
    I was able to find the software for the DEM-PCM1796.
    Paul
    Paul
    Thank you for your support.
    Can the software that you provided me use for DEM-PCM1795, too?
    Nishie
  • In reply to Yuta Nishie:
    Hi Nishie,
    It is the same software for both.
    Paul
    Hi Paul,
    Thank you.
    Later, please tell me the result of whether the software can be used on the server.
    Nishie
    Hi Nishie,
    What do you mean when you ask: "software can be used on the server"?
    Paul
    Hi Paul,
    "software can be used on the server" is Windows 7 or Windows 10.
    Nishie
    Hi Nishie,
    I doubt this software will run on Windows 10, but there is a chance it can run on Windows 7 with certain compatibility modes.  Most likely it will only run on Windows XP.
    Paul
    Hi Paul,
    Nishie
