TPA3245 have not worked normally if having applied 14V to PVDD and evaluated TPA3245EVM although the power supply voltage range is mentioned on page 3 of the user's guide as below(the AVDD which is the internal regulator output did not start up).
So, it can work normally when the power supply voltage is more than about 17V.
However, as a result of having evaluated two TPA3245EVMs, that threshold depends on TPA3245EVM.
Could you please doublecheck it ?
Kato
