My customer considers using PCM1808 and the sampling frequency is 48kHz.
Are any characteristics differences in the case of setting fsclk=2.048MHz or 4.096MHz?
Kuramochi
Kuramochi
Collin-san,
Thank you for your support.
Are any characteristics differences in the case of setting fsclk=12.288MHz or 24.576MHz at fs=48kHz?
Kuramochi
Hi Kuramochi-san,
Collin is out for the day so I will answer.
There is no impact to performance using one SCLK vs. the other. You may prefer to use a lower frequency SCLK from an EMI perspective and/or depending on board layout and trace lengths lower frequencies may be preferable, but the PCM1808 performance does not change assuming the clock is clean in both cases!
Zak
