We are using the LMX2531LQ257. We have encountered an issue where some synthesizers don’t lock on our PCB. We found the lock issue is due to the OSCin level. Our oscillator frequency is around 20 MHz.
Page 6 of the data sheet specifies “Oscillator Sensitivity” as 0.5 Vpp min and 2.0 Vpp max.
- Does this specification assume the oscillator signal is a clipped sine wave or a square wave?
- If the answer to question 1 is no, is it okay if the oscillator signal is a sine wave?
- Does this specification vary with oscillator frequency? In other words, is 0.5 Vpp sufficient at 20 MHz? We have found that 0.5 Vpp is too low at 20 MHz.
- If the specification does vary with frequency, what is the minimum voltage level required at 20 MHz?
Eric
