  • TI Thinks Resolved
LMX2492-Q1: fastest FSK and PSK modulation rates
Expert 5935 points
Part Number: LMX2492-Q1
Hi Team,
A customer is asking for the fastest FSK and PSK modulation rates LMX2492-Q1 will support?
Thanks!
Jonathan Geronga
  • Genius 11990 points
    Hi Jonathan,
    I'm not familiar with FSK modulation. My coworker will get back to you soon.
    Hao
    Clock and Timing Systems & Applications
    To view training videos on Clock and Timing Solutions please visit  TI Precision Labs ​​​​
    More information Clock and Timing System products: http://www.ti.com/clock-and-timing/overview.html
  • In reply to Hao Z:
    Hi Jonathan,
    The FSK rate restriction is set by the loop bandwidth as well as the frequency deviation. You can use PLL Sim to estimate the lock time from fo to fo+delta f, where delta f is the frequency deviation. A higher FSK rate will require higher loop bandwidth in order to reduce lock time.
    We don't suggest PSK, which I think is not robust enough.
