I am using TPL5010 in my project and I followed the recommended design mentioned in the data sheet. WAKE pin is directly connected to MCU interrupt pin. For testing I have added ~10K R_Ext resistor for a 8 sec t_IP and a 100 K pullup on RST without manual reset circuit.
But I don't see any WAKE signal coming out from TPL5010 after t_IP. Although RST signal is generating successfully, this is normal because without WAKE I cannot generate DONE from MCU.
Can you please tell me what is going on, as I have copied the exact circuit recommended in the datasheet.
Thank you,
leonahi
