I want to connect the output RFoutB of the LMX2592 using Channel Divider to a FPGA clock input.
Is the output LVDS compatible ? Is there a recommended method to connet this output to a FPGA input ?
Stéphane
Stéphane
Hello Stephanie,
The output is a sine wave if using direct VCO or square wave when you are using the channel divider. You will need to check the specifications on your FPGA input. What frequency, signal swing and slew rate does it require? You may need to use a buffer based on what your particular application is.
Vibhu
