Other Parts Discussed in Thread: TICSPRO-SW,
HI Expert,
My customer would like to set RFoutA=4928.67MHz.
They try to set each values in TICS Pro as below,
Fnum=13470000
Fden=245760000
Prescalar=2
N Divider=20
However, Fvco(MHz)=4928.67 became red.
Then, They changed the setting as below,
Fnum=449 (=13470000 / 30000)
Fden=8192 (=245760000 / 30000)
Prescalar=2
N Divider=20
Fvco(MHz)=4928.67 became white(OK).
Question1, Could you please let me know the limitation for Fnum and Fden setting? Do they need to divide by a divisible number? (In case of above condition, divide by 30000.)
Question2, If yes, this limitation is for TICS Pro only? or it is for even If Actual use case(not use TICS Pro)?
Muk
