Other Parts Discussed in Thread: LMX2582, LMX2594,
Hello team,
My customer found that the LMX2582 fails to lock when the system is reset by R0 register. This issue repetitively happens approximately one in ten systems.
This issue looks similar to what discussed on this thread. Could you please help me to address the issue?
Please find the internal link here for schematic and register configurations. (Please connect to VPN for download)
Details:
1. When powering on, the same register setting with system reset is used. After reset by R0, R125-R0 are set following the DS.
2. When power it on, the system succeeds to lock
3. When resetting the system, it fails to lock in 1/10 rate (in nominal temp.)
4. In lower temperature, lock failure rate increases
5. After failing the lock, it is very likely to lock when configuring R125-0 without R0 reset.
Questions:
1. In the previous thread, the user mentioned that this case depends on the IC temperature. Could you please elaborate on that?
2. In LMX2594 datasheet, it is mentioned that waiting sequence should be inserted before setting R0.
Should this sequence be applicable to LMX2572 as well? (Meaning after setting R112-R0, and then have 10ms waiting and setting R0 again.)
Itoh
