Hi team,
Could you tell me about the Absolute Maximum Ratings of the following pins?
*Absolute MIN voltage.
CONT(5pin), RESET(4pin), THRES(6pin), TRIG(2pin),Vcc(8pin)
*Absolute MIN/MAX voltage.
OUT(3pin),DISCH(7pin)
Sincerely.
Kengo.
Hi team,
Sincerely.
Kengo.
Kengo,
The specified minimum voltage is 5V for the supply.
For this condition the specified minimum voltages are:
Threshold Voltage 2.7V
Trigger voltage level 1.45V
Reset Voltage level 300mV
In Astable mode of operation the discharge pin is connected to resistor RA and RB listed in the product data sheet and discharges the timing capacitor. In Monostable mode of operation the discharge pin is connected to resistor RA shown in Figure 9. Resistor RA will act as a pull up resistor to the supply pin VCC as the timing capacitor charges, This pin and the output should not be forced with a voltage. These two pins should not exceed VCC.
Kengo,
What mode of operation will you be using? If the reset pin is tied to the supply it will follow the supply pin and there isn't worry of damage unless you exceed the max voltage or force a negative voltage below ground. The other pins should not exceed the supply or go below ground. We do not specify a minimum for these pins but they shouldn't be reversed biased against ground. Will you be applying a voltage to the control pin?
Just need some more details to understand your use case for better guidance.
Kengo,
I reached out to the design team and a good general rule would be to not go below -200mV. This would be the case where you reverse bias protection diodes and gives you enough headroom to avoid damage.
Chiris,
Thank you for your answer,
My understanding is below.
Is it correct?
->Absolute MIN voltage is -200mV.
-> How much is Absolute MAX voltage?
Is it a VCC voltage?
We care about the voltage applied to these pins.
Sincerely.
Kengo.
Kengo,
Minimum = -200mV for CONT(5pin), RESET(4pin), THRES(6pin), TRIG(2pin),Vcc(8pin)
The absolute max is
Kengo,
We do not specify a minimum on any pin, however those pins should also not go below -200mV or exceed VCC.
Kengo,
There should be care taken with the discharge pin current if shorted to supply. The discharge pin is a low impedance path to ground and the current through this pin should be limited under a fault. We do not specify a max voltage for this pin but the current should be considered in this situation.
