LMX2820: programming order
Part Number: LMX2820
in changing the VCO frequency using the cal data I have collected, does it matter what order I set the registers?  I suspect that I would change the N divider first, then followed by the capctrl  and then the daciset.
In general the specifics of implementing integer frequency hoping using the instacal are vague.  Do you have a flow chart or other description I can code to?
thanks,
mike
