My customer wants to generate 1MHz clock by source 1kHz clock.
Which should I select the device in TI's products.
There is no limit of operating voltage.
Naoki Aoyama
Naoki Aoyama
How about LMK02002 with external VCXO? Due to low Ref input frequency, they need to use narrow loop BW so VCXO based PLL is better than on-chip VCO in terms of performance.
The external VCXO module can be a low cost 10 MHZ device, which can be divided down by 10 to achieve the 1 MHZ output. You can use CLOCKDESIGNTOOL for designing the PLL dividers and loop filter values.
Alan
Hi Alan
Thank you for your very fast response.
I'm sorry but my customer wants to get a clock 1000 times.
A sensor output signal is 1kHz pulse. He multiply that signal and get a 1MHz clock.
So I search the device that Fin:1kHz and Fout:1MHz synthesizer.
Naoki
