My customer have some question about LMX2581EVM.
<Background>
My customer evaluated the LMX2581EVM.
Their configuration is as follows.
- OSCin is driven by the SG through the OSCin SMA.
- They modified the resistors related to OSCin as follows.
- Remove R6 and R14.
- Change R13 and L3 to 0 ohm.
- Make R15 51 ohm.
<Issue>
They observed big reference / PFD spur in about -65dBc in RFoutB+/-.
[Q1]
Is my understanding correct ?
Is there any other cause ?
<My understanding>
The causes of the reference / PFD spur are as follows.
- Configured as Fractional mode in spite of integer mode
- Effect of the spurs on VccVCO
- Effect of the spurs on VccCP
- Leakage Dominated Spurs
- Pulse Related Spurs
[Q2]
Is my suggestion correct ?
Are there any other good suggestions ?
<My suggestion>
- Set FRAC_ORDER to integer mode, Set PFD_DLY to the minimum setting, Disable Dithering.
- Change R28 to ferrite bead.
- Change R22 to ferrite bead.
- Change the capacitors of the Loop Filter to Film Capacitors from Ceramic Capacitors.
- Change the PFD frequency to low frequency and Change the Loop BW to nallow BW.
Hiroshi Katsunaga
