Do you have figures for additive RMS phase jitter for the LMK00334-Q1 with the PCIe Gen 2 high band (1.5MHz - Nyquist) and low band (10kHz-1.5MHz) filters applied?
Jack
Jack
Hi Jack,
Similar question has been asked on the forum before: https://e2e.ti.com/support/clock-and-timing/f/clock-timing-forum/844493/lmk00334-q1-lmk00334rtvrq1-pcie-2-0-jitter
The typical value for high band is 116fsRMS and the typical value for the low band is 27fsRMS.
Kind regards,
Lane
Thanks Lane,
Can we use the 116fs and 27fs figures as the max expected jitter over the operating temperature range of the device?
I know this was asked in the linked post but I just want make sure I've understood the response correctly.
Hi Jack,
116fs and 27fs figures was the max expected jitter at room temp for the device tested using PCIE gen 2.0 filters, and was reported as the typical value. It would still provide significant margin compared to the PCIE 2.0 limits of 3.1ps for high frequency jitter and 3.0ps for low frequency jitter.
There isn't enough data available to specify the max value. However, even if we used a multiplier of 1.5x times the typical to assume the max value, you would still have plenty of margin.
Kind regards,
Lane
