Hi team,
My customers want to know how to configure the unused output pins.
- For unused differential outputs, customers should either float the pins if this channel disabled by registers, or terminate the pins if this channel active in registers. Customer's question is that how to terminate the output pins? Placing a 49.9ohm pull-down resistor?
- For unused single-ended outputs, like only using P channel, how to terminate the N channel? Placing a 49.9ohm pull-down resistor?
Appreciate your answers, thanks a lot!
